Dell Vostro 1510 Laptop Logo
Posted on Oct 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After installing audio drivers, still it is not working.
Rusum Gupta
Level 2:
  • Expert 102 Answers
  • Posted on Oct 27, 2010
Rusum Gupta
Expert
Level 2:
Answers
102
Questions
0
Helped
19699
Points
440
Try this,
Click Start > In the Run box type devmgmt.msc, hit Enter > Device Manager comes up > Open the Sound folder > Right click on driver installed > Select Uninstall. Close Device Manager.
After that perform this step.
Click Start > In Run type, inetcpl.cpl > Add/Remove Programs comes up > Select Realtek ALC268 HD Audio (which seems to be your default audio driver) > Click Uninstall > Restart the computer.
After retsart go to  : http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R179426&SystemID=VOS_N_1510&servicetag=&os=WLH&osl=en&deviceid=16219&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=244276
Download and install the driver, retsart the computer and check.
Revert if the issue gets resolved or not.
1helpful
My compaq presario v3700 windows xp laptop audio is not working.
I see that your Laptop was not pre-installed with XP, it was with Vista. Installing XP on it, will be a downgrade which is not recommended by them (HP). In HP Laptops, there is always trouble making the device and drivers work with retail version OS.
Anyways, I got the audio driver for XP, you can give it a try....
The Audio is a High definition Audio and we can not install the Audio driver ditectly without installing the UAA (Universal Audio Architecture) driver in Windows XP. So, first install UAA driver (restart) then install Audio driver (restart).
UAA driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33566.exe
Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32864.exe
Audio & video is not working
You downgrade from Vista to XP right?
Installing your audio drivers on XP:- ***important
You have to install the "Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio (sp33867)" first, before intalling the audio drivers Conexant CX20549-12 Audio Driver for Microsoft Windows XP (sp41836.exe).
If you reverse the procedure your audio won't work.
Hope it helps.
Pci device drivers are not installed on my system i dnt know how to install. Due to this my audio device is not working
there no audio driver install at your pc that is why your audio not working the best thing you do is, intall a pci audio driver at your pc after that your audio will work properly
Audio driver don't work
you purchase original drivers and then install after install your audio drivers are worked.
5helpful
2answers
"install HD audio driver failure"
there is a trick of installing hd audio.Remove all the drivers.
First install the patch of winxpsp2 , it should be in ur driver cd somewhere in audio folder.
then remove it. Again install it and then install sound driver and all other drivers.
It will definitely work.
2helpful
To download audio driver?
u can download all your drivers from torrent.
go to www.mininova.com it is the biggest torrent site for softwares.
other i m sending link this is 100% working
Audio Driver: First download and install the UAA driver from the
following link before installing the audio driver:
http://asia.giga-byte.com/FileList/Driver/motherboard_driver_audio_realtek_azalia.exe
After installing this, download and install the audio driver from the
following link:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
My i install server 2003,it show a message sigmatel audio driver doesot work properly. i use intel LGA775 motherboard
  • the sigmatel audio driver it is your audio driver not work properly. first thing to do get the installer of your computer or cd driver of your computer. then insert into a cd-rom of your computer. then open the file of the cd driver of your computer then find the installer audio driver. then click the executable file wait until finish to install the audio driver.
1helpful
No audio
You must do this in order to get the sound working on the C700 series with XP, the LAN drivers can be found at driverguide.com:
This model of Presario has an audio controller that supports
the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) bus driver for high definition audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/sof...4000/sp33867.exe ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver from the above links you have
to restart the notebook and then install Conexant high definition
audio driver from the following link :
ftp://ftp.hp.com/pub/sof...4500/sp34200.exe ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Installing the audio drivers may result in an error, but continue
with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "audio device on high definition audio bus" and click update driver.
3. Select "install from a list or specific location"
4. Click next. Then select "don't search, I will choose the driver to install"
5. Click next and then select "sound, video and game controller" from the list.
6. Click next and then click have disk.
7. Click browse C:swsetupsp34200 folder and select the .inf file and click open and continue with the on screen instructions.
5helpful
8answers
Sound card drivers for win xp-sp-3
i have installed windows xp ser: p3 and my sound card is not working
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
