Question about Sharper Image SI785 Clock Radio
Buttons not working.....
The clock/display works but I cannot get any of the buttons to work (to even set the clock/alarm/date, etc.) nor will the radio or sounds work. I have tried the manual reset and no luck.
Any Ideas?
  • Stuarteee Feb 17, 2009
    I have s SI S1785 - the light has gone out, buttons do not work - I changed back up batteries, plugged in transformer, pushed on reset button in battery compartment but still out of order. Help!
In the battery compartment is a small button marked "reset". Push this in after the batteries are installed and the buttons should work. You will have to reset everything.
Posted on Jun 26, 2008
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
Dec 06, 2013 | Timex T309TT Clock Radio
How to set the time on a Bedol Squirt clock
The right button in the frame of the clock face is chooses mode; it cycles through alarm, date and time, in that order. The left sets alarm, date or time.
1)To set the time:
Press the right button 6 times until the hour display flashes. (Make sure it is the time and not AL = Alarm)
Press the left button until you have the correct hour (note AM or PM)
Press the right button again until the minute display flashes.
Press left button until you have the correct minute.
Press the right button then the left button; the colon should flash.
The clock is set.
2)To set the alarm time:
Press the right button twice until the hour display flashes. (Make sure AL is displayed in top right hand corner)
3)To turn on the alarm:
Press the right button once
Press the left button once
There should be a symbol which says "AL ON" near the centre top of the time display.
Press the right button 3 times until the colon flashes
The alarm is on.
There is also a way to get a bell symbol displayed at the centre bottom. (I didn't test what it does)
4)To set date:
Press the right button 4 times until the month display flashes.
Press the left button until you have the correct month
Press the right button again until the day display flashes.
Press left button until you have the correct day.
Nov 14, 2013 | Bedol International Group, Inc The Bedol...
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio on CKS1850
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Mar 15, 2011 | Emerson SmartSet CKS1850 Clock Radio
Set clock, date, alarm on SI686 CD/ Radio / Alarm Clock with Sound Soother
Can you clarify what you need help with? To SET THE CLOCK push the "Mode" button twice. (The current time setting flashes on the display) Once it is flashing, Decrease the hours by pressing "1" Increase hours by pressing "2" Decrease minutes by pressing "3" and increase minutes by pressing "4". If no additional buttons are pressed the time will reset in about 10 seconds and the display will stop blinking.
TO SET THE DATE press the "mode" button 4 times. The current date setting will flash on the display. Decrease the date by pressing 3. Increase the date by pressing 4.
Decrease months by pressing 1. Increase the months by pressing 2. The date will reset in about 10 seconds when you stop pushing the buttons.
TO SET THE ALARM Press the "mode "button once. The display will begin to flash. Change the hours by pressing either 1 (increase) or 2 (decrease). To change the minutes, press 3 or 4. 3 decreases the minutes and 4 increases the minutes. Once you have the time reset, leave the unit alone for about 10 seconds. the display will stop blinking indicating the time has been reset.
TO ACTIVATE THE ALARM push the round button on the far right. You will see the alarm icon come on or off on the LCD display on the right side. Be sure you have set the AM or PM time correctly on the alarm time. It helps to recheck this now as I have made this mistake several times.
If you get stuck on military time and want the 12 hour clock the answer is posted on this site, as well.
Hope this helps.
Dec 25, 2010 | Sharper Image SI686 Clock Radio
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
How do i set the time on 1440 T5K085
The instructions that came with my watch didn't work but after playing around with the buttons for a while i final came up with this: Press the mode button for 2 secs. The first display is the alarm. Press mode again and the time shows with the seconds flashing. Use the set button to change seconds, minutes, hours. Use the start/stop button to change from seconds to minutes to hours.This will then take you to change the month, date and day of the week. Mode takes you back to the start (time display). The alarm is changed in the same way.
To change from 12h clock to 24h clock keep the set button pressed (the alarm time is displayed) and press mode, the 'A' will disappear when in 24h mode
When the time is displayed press the start/stop button to show the date.
Not sure how to use the countdown timer or how to stop the alarm yet though!
Aug 13, 2008 | Timex Watches
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
T307S How to deactivate the alarms
Timex T307S
I lost my manual also so had to resort to relentless trial and error.
The problem with the alarm is that it is too easy to turn it on.
The 1 and 2 buttons on top of the unit with the alarm clock symbol turn each alarm on or off. Your only cue is on the display in the top line of the display which will have a bell followed by “RADIO” or “SOUNDS”, if the alarm is armed. If you see this symbol and want to disarm the alarm, press the 1 or 2 alarm button according to which alarm was on the display. It’s just as easy to turn the alarm back on either deliberately or accidently
Enter Alarm Setting mode by holding the 1 or 2 alarm button for about 2 seconds.
Display will flash – in this mode you will be able to do the following
Date Set Button – changes between Everyday/Mon-Fri/Sat-Sun
Arrow Buttons – adjust the time setting
Alarm 1 (Radio):
Mode Button – changes between AM/FM1/FM2
1-6 Buttons -- changes between stations
Alarm 2 (Sounds):
Mode Button – changes between SD1/SD2/SD3/SD4/Buzzer
If you don’t change any settings for about 5 seconds the unit exits the alarm setting mode.
Timex already has your money so I guess they are not motivated to publish their manual.
Feb 08, 2008 | Timex (T307S) Clock Radio
Daylight Savings Times Changed
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
  • This should work for all Smartsets, but I cannot make the guarantee (and no, I don't have any other directions, sorry)!
  • Adjusting the DST Start Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM1 buttons (at the same time). After 3 seconds the display will show the DST 'start' month, week, and date. It should be alternately showing "4 F" (April and first week week) and "4. 1".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the DOWN (or "-") button 3 times, until the display is showing "3" (March) and the week as "F2". It should alternately flash "3 F2" and "3. 11".
    3. After this is set, the clock should "automatically" reset itself
  • Adjusting the DST End Date on an Emerson Research Smartset:
    1. Depress & hold the MONTH/DATE and the ALARM2 buttons (at the same time). After 3 seconds the display will show the DST 'end' month, week, and date. It should be alternately showing "10 L" (October and last week week) and "10. 28".
    2. While still holding the MONT/DATE and the ALARM1 buttons, press the UP (or "+") button 1 time, until the display is showing "11" (November) and the week as "F". It should alternately flash "11 F" and "11. 4".
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
Oct 29, 2007 | Emerson Smartset Clock Radio
Sharper Image SI785 Clock Radio Logo
519 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
