Question about Garmin Rino 110 (14 Channels) 2-Way Radio
Rino 110 stuck in one mode
When powered on the unit is stuck in one mode, and does not respond to pressing any buttons. The only way it can even be powered off is to remove the battery. Any suggestions to reset or something?
  • bdjohns Oct 13, 2008
    I have the same problem, the rino 110 will blank out and display a flat horizontal line and will be frozen. I have to remove a battery and then put it back to restart. It will work for a minute or two then go into flat line mode again. Any solutions would be most welcome. Thanks.
There was a change to the WAAS satelite protocols. There is a new software download to fix the problem. The link is:
Posted on Oct 14, 2008
My garmin rino hcx won't upload satelites
Try performing a factory reset.
Be sure to save your favorites, routes, and waypoints before doing the reset as these will be deleted.
The factory reset is done with unit OFF.
Press and hold PAGE button and ENTER button and while holding the buttons turn ON the unit.
Reset is complete.
Dec 21, 2011 | Garmin Rino 530HCx 2.1 in. Handheld GPS...
It turns on i can barely see the screen; does it have a dimmer switch? and if so;how can I fix It if i cant see the sceen? thanks ssg figueroa
to brighten up the display, after unit is on press the power button again and you should get the light and contrast contols. works on all of mine.
Jan 14, 2011 | Garmin Rino 110 (14 Channels) 2-Way Radio
I have a Rhino 530hcx, the volume button is stuck...when the device powers on the device locks up....other than Garmin, where can I get this thing fixed?
I am not sure if you got this fixed but mine is doing something similiar except it is the button above the volume (aquire other users) I had to press the button repeatedly at different angles to get the button to unstick. I have had this happen a couple of times now and the whole unit freezes up. Poor design in my opinion as this unit has only seen the field 3 times.
Jun 20, 2010 | Garmin Rino 120 2-Way Radio
Cant turn on backlight
Click the power button again - don't hold it down, just tap the on/off button. The backlight by default is shut off when the unit is powered up. To turn it on you press the power button again
Oct 06, 2009 | Garmin Rino 120 2-Way Radio
Unit will not stay on. With new batteries installed, the unit turns on while power button is held down. It immediately turns off when power button is released. The batteries have never lasted long.
If using rechargeable batteries, your batteries are not getting charged. Check your charger, battery contacts and batteries. Clean contacts with a pencil eraser.
If using alkaline batteries, check placement of the batteries to be certain they are in the correct way, and also, clean the battery contacts.
Sep 07, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Can i reboot my rino 530 hcx?
Yes - press the Page (lowest button on the left side), Enter (push in the center joy stick button) and Power (top) buttons at the same time. Then use the joy stick to select Yes indicating that you want to reset the unit.
Aug 04, 2009 | Garmin Rino 530 GPS Receiver
Garmin Rino 110 Posted by nightjar on Jun 29, 2008 My two 110's have same problem. With two new sets of different brand NiMh rechargeables the problem still exists. Both units get warm and flatten the...
Re : " Both units Garmin Rino 110, overheat and flatten the batteries within 2 hours"
That is a factory defect related to a bad contact inside the unit.
If you contact garmin and insist to talk to a supervisor (second line) you can have both Rinos replaced.
Ensure it is not a bad batteries problem first testing a replacement battery, both batteries may have deteriorated at same time.
Buy first a replacement battery at Garmin eTrek, Rino 110/120 NiMH Battery,
If that does not solve the problem call Garmin:
See: Garmin | Contact Us
Feb 09, 2009 | Garmin Rino 110 (14 Channels) 2-Way Radio
Garmin Rino 530 stuck in DEMO MODE
Try a hard reset....with power off hold enter button and page button while turning on unit ....this should reset to factory setup, should now be able to switch out of demo mode
Jun 11, 2008 | Garmin Rino 530 GPS Receiver
Garmin Rino 530 HCX Will not receive
check the volume settings for the radio
factory reset is: with unit OFF press and hold PAGE button and ENTER button while holding buttons turn ON unit reset is complete.
May 11, 2008 | Garmin Rino 530 GPS Receiver
Unresponsive buttons
First, try unplugging the unit for a couple of hours. That should reset the internal microprocessor. If that fails, try pushing all of the buttons one at a time. If one of them is stuck, nothing will work properly. You should be able to feel the button working. Report back here with your results.
Mar 12, 2008 | Sharp XL-MP130 CD Shelf System
Garmin Rino 110 (14 Channels) 2-Way Radio Logo
179 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
