Question about Logitech G25 Wheel And Pedals Set
Broken Spring on Shifter
Just below the shifter cover are 2 small springs that aid in the shifter returning to neutral when in the sequential shift mode. One spring is broken. Would like a source for replacement preferably something local. Unit is well out of warranty.
Thanks,
Ralph Kemmerer
  • bfrancis Aug 30, 2008
    I have new replacement G25 shifter modules available on Ebay, seller ID is 4tniner4life - 8/28/08
    Genius:
  • 2,035 Answers
This seems to a problem the spring is not that easy to get but you try giving it local hardware service center and get it fix but make sure you explain to them clear this is problem ............
Good luck............
Posted on Jun 11, 2008
1996 royal star will not shift out of neutral
Hi, Donald and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
shifter still stuck
1996 YZ250 has shifting problems won shift past neutral
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
YAMAHA XVZ1300TF Owner Manual
Mar 21, 2017 | 1996 Yamaha Royal Star XVZ 1300 A
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
Honda crf230f hard to shift into 2nd gear
Hi, Anonymous and the usual suspects are:
1. Clutch not adjusted properly.
6. A loose shift lever on shifter shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
crf 230 1st gear shifting problems
Shift Problem 2nd to First stuck in Neutral
Honda 2004 CRF250X Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CRF230F Owner Manual
Dec 26, 2013 | Honda CRF 230 F Motorcycles
2007 Honda VTX 1800 C shift pedal does not come back up
Gear Shift Return
http://www.allworldauto.com/comments/2002_HONDA_VTX1800_comments_and_complaints_21-9566-2002-1.html
Honda VTX1800R Owner Manual service manual, not owners.
https://www.partsfish.com/page/oem-parts-for-honda
Jul 11, 2012 | 2007 Honda VTX 1800 C
Can not select neutral on yamaha fazer 1000
6. The shift lever is loose on shifter shaft.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Fazer 1000 or FZ1 gear shifting problem
http://www.r1-forum.com/forums/105-07-08-r1-mechanical-help/320723-only-when-hot-cant-find-neutral-hard-shift.html
Yamaha FZS1000 2001 Service Manual
YAMAHA FZS1000 Owner Manual
Feb 26, 2012 | 2003 Yamaha FZS 1000 Fazer
I have a xjr1300 2001 and it is hard to get neutral gear
Hi, Lowfieldss and the usual suspects are:
Why is my bike so hard to get into neutral
1999 2003 Yamaha XJR1300 Service Manual Moto Data Project
YAMAHA XJR1300 Owner Manual
Aug 02, 2011 | 2001 Yamaha XJR 1300
Shifter Not returning to start postion after shifting gears.
If the shifter is not returning to it's "center" position, the shifter pawl spring is probably broken in the transmission. With the engine off and the bike on the kickstand with the transmission in neutral, gently depress the shifter lever down until just before it shifts. Then, let go of the shifter and see if it springs back up. Do the same thing lifting the shifter towards second gear. Make sure there is no binding in the linkage. If you don't feel the spring pressure on the shifter, this is an indication that the return spring is broken. Harley had a problem with this on their 5-speed transmissions. Fixing the problem is a major job. You have to disassemble the entire primary drive and pull the trapdoor with both transmission shafts out of the transmission to get the shifter pawl shaft out. I strongly recommend the purchase of a service manual if you plan on doing this job yourself.
Good Luck
Steve
May 20, 2011 | Harley Davidson XL 1200 C Sportster Custom...
1994 Kawasaki VN 750 Vulcan transmission stuck in neutral
Hi, Johnwsmith24 and the usual suspects are:
1. Improper clutch adjustment or not disengaging.
11. Shift lever loose on the shift shaft.
http://www.vn750.com/forum/26-transmission-rear-end/10507-shifter-stuck-neutral.html
Stuck in neutral lost all gears Kawasaki Forums
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
1994 Kawasaki Vulcan 750 Owner Manual
May 01, 2011 | 1994 kawasaki VN 750 Vulcan
1991 softail will not go into 3rd gear.it will go from 4th to 5th
Without being able to see and mess with the bike a bit, I would guess that you have a shifter pawl spring broken in your transmission. It's either the return spring or the spring on the pawl itself. To test the spring, start from the "neutral postition" of the shifter. Regardless of the gear the bike might be in, when you are not pushing down on the shifter or lifting up on it, it is in the neutral position, where it normall sits. Now, using your fingers push down on the shift lever until you feel the transmission start to shift, you feel a resistance. Stop right there, do not shift the gear but allow the shifter to return to the neutral position. Now, lift the shifter with your fingers until you feel the resistance of the transmission getting ready to shift. What you are feeling for is the resistance of the shifter return spring. Does it feel the same in both directions? If not, the spring is broken. If it does, then the problem is something else.
Still if the transmissio will not shift into a particular gear, something is wrong inside the transmission and you'll have to go into it to find the problem most likely.
Good Luck
steve
Feb 27, 2011 | 2000 Harley Davidson FXST Softail Standard
95 harley ultra classic stuck in gear. Was
There's only two things that could possibly make contact with the top cover and cause any problem. One is the shifter pawl and the other is neutral switch.
The shifter pawl return springs are notorious for breaking in the five speed transmissions. I've replaced a load of them. Take your foot shifter pedal and lift up on it until the transmisson just tries to shift. Then go back to the center position and press the lever down until the transmission just tries to shift. Does the spring pressure feel the about the same in both directions. If not, the shifter pawl return spring is broken.
With the top off, you can inspect the small spring on the sfifter pawl itself. See if that spring is broken. This is about the only thing that I know of in a five speed that will cause shifting problems. But then, I never claimed to know it all.
Good Luck
Steve
May 31, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Logitech G25 Wheel And Pedals Set Logo
371 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
