Question about Zebra 105SL Thermal Label Printer
Zebra 105SL - White Line
When the printer sits unnused for a period of time (12 + hours) the 1st label out has a white line running through the bar code approximately 1/2 in from the label bottom. Then next label also has the line though much more faint. Thereafter, as long as the printer runs, the printing is fine.
Thanks your the solution. This helped me a lot.
Posted on May 05, 2008
SOURCE: Zebra 105sl - printer does not print correct size
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Posted on May 19, 2008
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
SOURCE: Poor Quality Print on Zebra 105SL direct thermal
How many labels has the printer printed? Because it sounds to me like you just need to replace the print head.
They are around $400 from whomever your supplier is, and very easy to replace.
Posted on Nov 21, 2008
I've had this problem. I changed the margins and it solved it.
Posted on Jun 09, 2009
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
Zebra 105SL is cutting off bottom line
check the length and the with from the driver, if is the correct with the current label. check the length and the with from the printer setings.
Nov 04, 2010 | Zebra 105SL Thermal Label Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
How to install a zebra 105sl printer
Install? Well that could mean a lot of different things. Just plug it up and run the ribbon and labels through their correct paths. I don't know anything about your network. (If you even need to set it up that way.) You can just connect it to the back of your PC. Follow this link. This will tell you all about the specifications of the 105SL. Not really your connections though.......
Jul 09, 2010 | Zebra 105SL Thermal Label Printer
Our company has several Zebra printers that print out barcodes that are scanned using handheld scanners for many things including inventory management. The labels that come from ONE of these Zebras...
Power off printer. Press and hold pause button while power on. This will print dark black line across the entire label. Check for white vertical lines. If you see any in the area of the label where you are experiencing a problem then the printhead should be replaced. Power off and on to exit diagnostics.
Jun 25, 2010 | Zebra 105SL Thermal Label Printer
On Zebra 105Se printers, what is the a command line to allow label length calibration (2-3 labels used), but not sensor sensitivity adjustment (which wastes so many more labels). I know it exists, as...
The line is part of the ZPL (Zebra programing Language) set and can be downloaded at
The command you want is on page 187.
Jan 14, 2010 | Zebra 105SL Thermal Label Printer
I have a Zebra 105-SL and it seems not to recognize the distance between stickers since it prints a couple and then jumps a couple more.
Sounds like the white platen roller under the printhead needs to be cleaned or the printer needs to be calibrated.
Sep 26, 2009 | Zebra 105SL Thermal Label Printer
White vertical line runs through a shipping label
The problem is that the printhead is damaged and will have to be replaced. Assuming there are no other letters in the TLP2844 model number you gave then the part number for the printhead is G105910-053 and will cost around $100. Hope that helps.
Aug 26, 2009 | Zebra TLP 2844 Label Printer
After About 10 tickets a white line will start showing up in the
If printing with ribbon, check to see if you have ribbon burnt onto the printhead. If so, lower the temp of the heat on print. Or you can speed up the print speed.
I have seen this happen alot when the ambient temp is low, and the printer tries to make up for the differences in temperature.
Check the hed first..
Jan 08, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
55 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
