Question about Sharp Aquos LC-22SV6U 22 in. LCD EDTV
No sound I have a model LC-22SV6UM. a green light stays on where there is an OCP indicator and I get no sound.
    Novelist:
    Champion:
  • 203 Answers
I have ran into this symptom on that set. What I found after hours of troubleshooting was that on the bottom of the circuit board that connects to the speakers inside of the set, there is a heat transfer putty that actually melted allowing the audio heatsink to touch the bottom of the circuit board. There were burn marks where the piece of metal heatsink had arced across. The disassembly/reassembly process was the hardest part of this repair because of the amount of screws and the way the boards were mounted on top of each other in close proximity. If you attempt this yourself look for a small 10 ohm surface mount resistor to open on bottom of board or any other charred component. Then discard or resecure heatsink that cuased problem. Either will work. Good luck, Russmann.
Posted on Jun 09, 2008
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
I have a Sharp AquosTV model LC-52D64U. My kids were watching and turn it off and 1 hour later I try to watch tv but it won't turn on. A flashing green power light and ocp lights are on, the power
Do a hard reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If it do not help you, make sure that the main board is faulty. Short circuited component/s at it. Contact any service technician; or the authorized service center. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty
Oct 18, 2014 | Televison & Video
How do i fix my sharp aquos model LC-46D64U serial # 801811005
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 08, 2014 | Televison & Video
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Green lightv flashes then stays on but no sound or picture
Do you mean that the tv stays on but there is no sound or picture? I am not sure whether the green light indicates standby mode or that the tv is on, on this particular model. So please clarify this.
May 05, 2011 | LG 42LC2D 42 in. LCD HDTV
Sharp lc 37sb24u both power and ocp are blinking. power power power and ocp power and ocp power and ocp repeat forever.
I have the same problem. I can get the video by pushing the power button on top of the TV after using the remote and getting the power and ocp light dance.
Nov 16, 2009 | Sharp LC-32SB24U 32 in. LCD TV
My sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
Nov 15, 2009 | Sharp Aquos LC-32D40U Television
Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Dec 10, 2008 | Sharp LC-37D4U 37 in. LCD Television
Sharp Aquos LC-22SV6U 22 in. LCD EDTV Logo
87 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
