Question about Toshiba CF35F50 TV
No cable reception
Dvd works on tv but when i switch to tv mode i do not get any channels. I do not have the original remote for my Toshiba CF35F50, but i am pretty sure that I switched to tv mode manually. I tried the same coaxial cable on other tvs in the house; they work fine. HELP!
Thank You In Advance!
  • gr0235 Jul 09, 2008
    I have the same problem as imashark. My tv will only get two channels 32 and 22 I think. Both are blue with no picture. I think the channels have some how deprogramed.
    I have a tuner problem. We are trying to run the cable through the VCR, but do not know the code to program the remote. Where can we find that information if you have lost our user manual?
Hi, is problably your turner its damage
Posted on Jun 10, 2008
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
Moved, no longer have cable and not getting any channels via attenna. Is it just bad reception or do I need a digital converter because of the change to digital stations?
Could be bad reception and or make sure the tv which was in the cable mode when you had cable now needs to be in air or antenna mode. IF you have another tv that works ok then you will know the channels just need to be reprogrammed for over the air signal. Go into the menu of tv and find program channels and switch to air or it might say antenna..
Oct 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Can't watch dvd
You need the original remote controller to be able to switch input modes.Universal ones don't work. If you don't have the original remote and can't find it ever then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Oct 11, 2008 | Symphonic ST420FF 20" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
Mar 16, 2008 | Toshiba 24AF45 24" TV
I don/t have remote control
If there is no button on the TV to go to the video channel or channel 3/4, you'll have to buy a universal remote.
Dec 27, 2007 | Emerson EWF2004 20" TV
Lost Remote
the sony rm-v310 universal remote solved my problem. its about 15 bucks and worked on my symphonic 20" tv. bestbuy should have one.
Dec 15, 2007 | Symphonic ST419E TV
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
Toshiba cf35f50
Bad connections in tuner. If your really careful, lots of very small parts, you can resolder the cracked solder ground connections to the metal box and metal shields.
Oct 28, 2007 | Toshiba CF35F50 TV
Televison & Video Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
