Question about RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7 Hi, How can i determine if its the color wheel? You think it could be the color wheel?
  • RCA Master
  • 8,617 Answers
The color wheel is the first item that should spin when power is pressed. It could be the color whel. I hate to guess as you could end up spending money needlessle. I suggest you go to the link I am posting as they have the trouble shooter manual for 29.99 and they will email it to you and it takes you step by step to explain what the problem is.just click on HD50LPW175 in the RCA section and thats the trouble shooter for your model. Cause I hate to say what it could be cause that could cost alot of money buying parts that you dont need. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 09, 2008
HI. Would you have the best picture wizard set up settings for an Lg47lm640t-za tv please? Thanks, John
Use your eyes to determine quality; only they really know. FYI, when determining the best color and tint, when you view the setting, think to yourself, "do people really look like that color in real life"?
Nov 16, 2014 | Televison & Video
About a week ago I replaced the lamp in my samsung hls24266 with no incident. Now when I turn the tv on, I hear a very loud humming noise. I tried disconnecting the coaxial cable but it does not go away....
I can't explain the timing of your problem and why it showed up after lamp replacement, but Samsung color wheel failures are usually associated with a rather loud hum. I would removed the back, jumper the lamp door switch and try to determine exactly where the hum is originating from. I think you'll find the color wheel is the culprit.
Bill W
integrityhomeworx.com
Mar 08, 2011 | Samsung HLS4266 TV
Red colour on presentation not displaying through toshiba make projector
hi,
i think ur projector ha problem with color wheel synchronization. check the color wheel rpm counter sensor. there will be a mark on color wheel for making counts. if dust deposited in there the counting will not become correct. clean the color wheel and re-fix it and test again.
ok
Jan 05, 2011 | Toshiba TDP-MT200 Multimedia Projector
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
High frequency noise
Hi. The most common cause for this is the color wheel. Replacing it requires removal of the engine/optical block. I'm not sure of your level of expertise but if you want to give it a try go to this website: http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ It'll give you some idea of what you're up against. It is similar to what you'll have to do but I don't think your chassis is exactly the same as this one so some things will look different inside.
Sep 11, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
There is a whining sound upon powering up my HL-P6163W which softens after about 5 minutes, but doesn't disappear completely. I think the source is either the color wheel or the cooling fan. How can I...
It the Colors wheel,cooling fan will shut down,if it start making noise to the fan,because the whole projection egine and the bulb link to it.The fan have to run a certain RPM to keep the tv running without problems.These colors wheels run 1000 RPM to start to give the tv colors and it make out Flexy glass and plastics.What ur opinion,who will give u the problems,first as parts wise.Ok any noises like whinning in the tv alway the colors wheel starting to buckle and warp.Getting worse make motor noises and briddles enough will brake and shatter it into ten of hundred of pieces.Who know,than inside what else will cause the rythum of the RMPS running of the tv,when u replaced it.
Jul 31, 2010 | Samsung HL-P6163W 61" TV
When I turn the tv on It makes an awful high pitched sqeeling sound for about 5 secs then silence then back again. Its a pattern. No Picture and lamp isn't coming on. Im thinking the lamp is trying to come...
Have the color wheel replaced on this unit, The high squeal is the color wheel bearings gone bad. Fortunely on this unit it can be replaced with out purchasing a entire optics engine assembly. The unit will not ignite the lamp until the color wheel has gotten to a pre-determined speed. Around 9600rmp, if it does'nt then the ballast will not get the signal all is well and ignite the lamp.
Nov 07, 2009 | RCA Televison & Video
My tv is a samsung dlp. i have determined that
most of the time you just need to replace the color wheel; the jumper they are talking about is on the DMD board which is a metal box attached to the light engine---if the jumper needs to be removed you will have a working set but the color will look odd--usually missing blue or red---it is a small two wire plug with a jumper and can be removed with a hemostat or needle nose pliers.
If you buy the color wheel I have specific instructions that you will not find on line to avoid problems when you replace it--lots of people think they can do it until they try and fail.
if you need direct help: etower.766@netzero.net
if this has been helpful I would appreciate your vote here.
Steve
Aug 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Hplpw175x7
If the color wheel was the only problem the power supply should be good
Jun 02, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
I would try the power supply first as the ATC336 has a history of the bad power supply boards.If the power supply doesnt fix it then I would think it may possibly be the ballast
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
