Need schematic on series 260 / 130 watt amp. brd. circa. 6/9/72. In particular value of 1/4 watt resistance in input diff. pair coll. ckt. from B- rail & 1/4 watt resistance in coll. ckt. pnp class b driver to B- rail.
  • 1,512 Answers
Hi REBECCADAVIS
How did you get on? Need a cricuit diagram? There is one in the back of this manual.
regards
Robotek
Posted on Jun 10, 2008
Where will I find a schematic with wattage values for all the resistors
Use this in Google to fine manuals and schematics:
Epiphone junior amplifier manual Google zoeken
Most resistors are 1/4 watt, unless something is added in the schematic.
You also can deduce the wastage, because for every size is a wattage, or the other way around.
When you are not sure, and it fits, use a bigger resistor. The same resistance (ohm) but a higher wattage is no problem as long as it fits in the housing.
Mar 15, 2015 | Epiphone Valve Junior Tube Amplifier Head
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Dec 26, 2013 | Paradigm PDR 8 Subwoofer
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
What is the cprimary load on a 12volt to 240 volt 300watt inverter
Ohm's law tells us that: volts = amps x resistance and watts =volts x amps. Watts (300) = volts (240) x Amps (?); or 300 / 240 = 1.25 Amps That means the inverter can supply up to 1.25 Amps to a 240 volt load.
The primary is 12 volts, this is just 1/20th of the secondary 240 volt output. Since the best you can ever get is 100% efficiency -this means you'll need to supply 20 times the current. 1.25 Amps (at 240V) x 20 = 25 Amps (at 12V). As a check, from above Ohm's law that states Watts=Volts X Amps we get: 12VDC x 25Amps = 300Watts. Check!
Some side notes. The Ohms law used above is for DC circuits and purely resistive loads on AC circuits. I do not know what your 1.25 A @ 240VAC load is - but I suspect it won't be purely resistive. Also, since we're working with an electronic inverter as opposed to a transformer and DC rectifier there are some things that push losses higher. You might need to provide a 30 Amp 12 VDC source voltage in order to provide the 1.25A @ 240VAC output. Lastly, I wouldn't not run the output at maximum for long periods of time - or at all. 1 Amp @ 240VAC would be much better.
I hope this answered your question & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Electronics - Others
What is the value of the resistor that burns up when to much RF power is input?
Hi wrightjc2,
Most common burned resistor are those with low resistance because it acts like a fuse to avoid further damaged to some parts if shorts,overload happened. But still best to have a schematic diagram to identify the burned one. If you haven't a schematic you may get the resistance of the resistor, measure it to the middle where the burned cut out, add the resistance from one half side to other half side. You may now have an Idea what may be the value of the burned resistor.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 25, 2011 | Pyramid (Swr14) Swr&Power Field Strength...
PV Delta Blues. Resistor R-58. What's the value and wattage?
It appears to be a 430 ohm 5 Watt FLAMEPROOF resistor... The resistance value could also be 470 ohms...
Here is link to a 430 ohm:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=PPC5W430TB-ND
Here is link to schematic, however the resistance value is blurred but starts with 4 and is three digits leaving only 430 or 470 as the value:
http://elektrotanya.com/peavey_delta_blues_sch.pdf/download.html
Jan 19, 2011 | Peavey Classic 30112 Tweed
Where can I get a schematic of the circuit board for the MG100DFX. The main fuse as blown and I need information on wiring connection to the transformer and values of other components.
Just a hint to troubleshoot: Connect a 100 Watt light bulb in series with the hot side of the power line into the amp. Make a cord with a light socket and a receptacle to plug the amp into. This acts as a resetable fuse and will send enough current through the amp to not fry stuff, but enough to do troubleshooting.
Apr 01, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I want to know what is the resistance value R32 - marshall g15rCD 15 watts
The value of r32 on the g15r cd amp is 10 Ohms 1/4 watt Brown-Black-Black
Dec 20, 2009 | Marshall 15 Watt Guitar Amp
Power supply burnt
R106 is a .5 ohm. It is green,black,gold, and silver. I believe it is a 1/2 watt resister
R103A is a 27 ohm and R108A is a 470 ohm resister.I have no schematic.
Sep 22, 2008 | RCA DRC8335
Need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
Mar 24, 2008 | Hitachi 57SWX20B 57" Rear Projection...
297 people viewed this question
 Grubhead
Grubhead
