Question about HP Office Equipment & Supplies
Can't get the HP director open so I can change the size of the type
I still don't know what to do for my problem. I thouight it was free. All I need is to know how to change the size of the type so it isn't so hard to read when you print something
Posted on Jun 10, 2008
When I scan a document and choose 'save a copy' to the desktop, it is in pdf format. Instead I need to scan and have jpeg. How do I do this?
  • open hp director (click on the hp director icon) on the computer
  • select the option SCAN PICTURE to automatically set output type to jpeg
  • if that does not work,click on settings on the top,scan settings and preferences,select scan document settings or scan picture settings or the scan preferences menu
  • change output type from there
Jul 27, 2011 | HP PSC 1510 All-In-One InkJet Printer
Used to print fine, however, recently, has become EXTREMELY slow, also, when tried to go to HP Director to check setting, will not open?
This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper.
Follow these steps:-
  • Click Start , point to Settings , and then click Control Panel.
  • Double-click Printers and Faxes .
  • Right-click the appropriate all-in-one, and then click Printing Preferences .
  • Click the Paper/Quality tab and under Type is select Plain Paper .
Have a nice day...don't forget to rate the solution.
Feb 19, 2010 | HP Photosmart 2710 All-In-One InkJet...
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
Can't open Hp director
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Dec 25, 2008 | HP Scanjet 3570 Flatbed Scanner
Scan to computer
Several ways to control your scanner:
From this HP link
Changing scan settings in HP Director
Scan settings include resolution, output type, and file type. These settings can be changed using HP Director.
  1. Open HP Director, if it is not already open:
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Director .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Director .
  2. In the Select Device list, select your product, if it is not already selected.
  3. Click Settings , and then point to Scan Settings & Preferences .
  4. Click the scan setting menu that corresponds to the type of file you are scanning.
    • Scan picture settings : Designed for scanning pictures, including any type of non-text image, such as a drawing, logo, or photograph
    • Scan document settings : Designed for scanning documents
    • Scan preferences : Control scanning preferences, such as automatically straightening crooked images
    • Button settings and Scan to... setup : Control the defaults for the scanner buttons on the control panel of the product
    After selecting the appropriate menu, the corresponding window opens.
  5. Change settings as appropriate, and then click OK . The scan setting window closes.
  6. Click Scan Picture or Scan Document HP Director to scan with the changed settings.
From this HP link
Using the Advanced Scanning Features of the HP Solution Center Softwaretoo large to paste - just follow the link above :)
Here the main site for the scanner - click here
Nov 18, 2008 | HP Office Equipment & Supplies
Hp 6110 all in one hp director not working.
try to do the following:
1. Double-click the HP Director icon to load the program into the memory. You will not see HP Director open at this step. Do not click anything else on the screen until Step 2 is completed.
2. Press the Alt key and the Space bar together, and then
select Minimize from the menu that displays in the upper left corner of the window. If necessary, click it again until HP Director minimizes.
The HP Director software now appears as an item on the Task Bar .
3. Click HP Director on the Task Bar . The software opens and displays normally.
4. Repeat Steps 1 through 3 every time the HP Director software is used.
or
  1. Go to the HP Software Download Page .
  2. In the Enter a product number text box, type the printer model, and then press Enter .
  3. Under Product search results , select the printer model.
  4. Select the operating system.
  5. Under Update , click Critical update to resolve an issue with HP Director after installing Internet Explorer 7 .
  6. Follow the instructions that display on the screen to install the update.
Cause:
In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7.
Sep 02, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
Seeker5211
Seeker5211
