Question about Goodman GMS90703BXA Heater
Blower starts ans stops
When using the Air Conditioner, the Goodman blower will start and stop about a minute later.
  • 78tman Jul 31, 2008
    Goodman Model GMP gas furnace after thermostat is satisfied on cooling cycle vent fan is initiated and runs intermittently. Design sequence does not indicate that vent fan should operate on cooling cycle. Any possible causes and/or solutions?
  • 1,420 Answers
Your system has a number of blowers and fans. Are you refering to the "Room Air Blower"? If so, at what point does it start? 30 seconds after you turn the air on, 1 minute, etc...? Does it ever come back on? The more you help us with information, the more we can help you!
Posted on Jun 10, 2008
Goodman package heatpump blower motor contant running
check your themostat fan mode switch to see if it in on or auto. It should be in auto. If this does not stop indoor fan motor, (it may take up to 2 minutes for the fan to stop, preprogrammed shutoff in the thermostat and fan control cards may make you think the fan has not stopped ) If this does not stop the fan the fan control board in your air handler has a green wire shorting to 24 volt signal in the theromostat wire or the contact on the blower control card is stuck and will need replaced.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
My air stops running inside before it get to the temp. Its set for but the outside unit keeps running and after a minute or two the air will start blowing inside again but the outside unit never turns off...
you have a possible thermal overload problem in your furnace blower motor dirt will cause this problem when it doesnt allow air across the windings of the blower motor if not dirt the motors going bad and getting hot use a shop vac and eliminate dirt keep your filter changed and your evaperator a coil may also need checked for cleanliness this will require cutting into plenum my advice someone qualified and remember dirt kills
Jun 18, 2010 | Goodman CKL36AR36 Air Conditioner
Air conditioner blower stopped working; checked
On ford and chevy models the blower is something common to go out. In some cases you can hit the blower with a hammer and if it starts working that is your problem it will be a bad blower. if not it can also be the blower relay located at your fuse block, and last it could be your speed control located on your ac cluster
Aug 10, 2009 | Heating & Cooling
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Inside blower not starting every time
That's a weird problem. I wonder if the outside compressor is drawing down the voltage in the breaker box enuff to keep the blower from starting up. If you're set to cool but the thermostat is NOT calling for the AC, can you manually turn the blower on fathfully? If so, I would check all wiring connections in the breaker box to make sure they are tight and free from tarnish or corrosion. You may even need to contact your power company and have a higher amperage line installed outside. Do your house lights blink noticably when the compressor kicks on?
While you're resolving this, you could start the blower manually and just leave it on. The compressor cycling on/off shouldn't stop the blower once it's running and it won't draw much current... couple bucks a month maybe.
Hope that helps...
Apr 04, 2008 | Goodman CKL24AR24 Air Conditioner
Goodman GMS90703BXA Heater Logo
75 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
