Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool dishwasher will not drain model # du912pfgbo
Please help. how do I fix the problem it will not drain
  • Anonymous Feb 07, 2009
    whirlpool dishwasher will not drain (standing water) help?
  • 246 Answers
Usually it is one of two problems. If you put the knob on spin and there is no noise, it is usually a bad lid switch. This can be easily checked by lifting the lid and listening for a click noise when you put it back down. If you hear a humming noise, I would check your pump for an obstruction. (Tilt the machine back and look for the white plastic with 2 black rubber hoses towards the front, center of the machine. Remove one of the hoses with a bucket and some towels at the ready to catch the water. After getting the water out of it, check inside the white plastic (pump) for any forign objects)
Posted on Jun 15, 2008
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Won't start/run. CLEAN light blinks continuously. manual drain (CANCEL)button works model number DU1100XTPQ9
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
The manual for the DU1100XTPQ9 is here: http://www.managemylife.com/mmh/owner_manuals/4164/WHIRLPOOL-Dishwasher-L0704454?brand_name_search=DU1100XTPQ9+WHIRLPOOL . Various parts diagrams and links to purchase the parts are here http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPQ9/1198/0130000 .
I hope this helps.
Jun 20, 2011 | Whirlpool Dishwashers
Whirlpool dishwasher will not drain. If the motor is tied into all fill and drain functions then the motor is good. I removed the drain hose and primed it with a total clear line I am in the dark.
here is the schematic for your entire machine http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU2400XTPT7/1198/0130000?searchedModel=GU2400XTP&blt=06 have you check the drain pump which is seperate from the motor? the motor basicly runs the sump with water going on the inside of the machine the drain pump is drains out the water part number 17 in this next diagram if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
heres the pump and motor section link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0512156-00008.png
Feb 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I recently replaced the chopper in my whirlpool quiet partner III. now it won't drain. I can push the cancel drain button and hear the pump running, but nothing happens. I tried reversing the wires to...
It sounds like you've done a lot to try and fix your dishwasher. Make sure your air gap is not plugged up and double check the drain hose. If those are clear change out your drain hose. Part#8270145 the elbow connector sometimes have a bad check valve and could keep it from draining.
Hope that helps Thanks please rate me
Dec 11, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher model DU912PFGBO drains very slowly and not anywhere near complete
You may have something obstructing the flow of water through the drain hose. You need a tech to check where the problem is.
http://tclaundryrepair.com/
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
I own a whirlpool undercounter dishwasher model number DU925 scgq3, and it will not totally drain. We have taken the drain hose off and no blockage? Please HELP!
hi did you take the drain hose off at the sink or off at the motor if not at the motor then check the motor drain hose thanks the appliance doc
Sep 27, 2008 | Whirlpool Dishwashers
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Did not drain after wash
My Whirlpool dishwasher model no. DU960PWKQ1 will not drain after wash. Dismantled impeller/strainer and there were no clogs.Drainline is clear.
I think motor is reversible, so there is no drain valve? HELP ME PLEASE.
Jan 13, 2008 | Whirlpool DU960PW Dishwasher
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
256 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
