Question about Canon PIXMA MP130 All-In-One InkJet Printer
Alarm light flashes red.Thats it.Nothing after that.Doesnt work reset/stop or any other key. Please help me to find solution. Thank you
  • 3 more comments
  • kimyhood Jun 19, 2008
    Alarm light flashes and nothing else happens. Also, I receive a Service error 5200. Please help if you can.
    Thank you
  • Anonymous Jun 27, 2008
    the red lamp is blinking and nothing is working
  • keithkeb3 Jul 05, 2008
    alarm light flashes,readout said please wait, nothing works.
  • Anonymous Jul 10, 2008
    I have a same problem.Nothing is working  other than alarm light .
  • mcshanejp Sep 02, 2008
    same problem with mine! flashing light and please wait disply. Whats wrong??????
This last is a stupid answer..sock
Posted on Aug 26, 2008
Unplug power cord from printer's back, wait a few minutes , plug back in.
Posted on Jul 01, 2008
Security light flashes and it won't start
top
CODE ALARM SYSTEM
information is always subject to change and correction Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm only Press the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter “UNLOCK” button once OR turn the ignition switch to the “ON” position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
top
Jul 10, 2008 | 1996 Subaru Legacy
Alarm stopped working
sounds like the system is in valet mode.
locate a switch under dash if a toggle switch is found then turn on key and flip switch. turn key off if led is off try alarm.
If a push button switch is found then turn ignition on and press the switch for 10 seconds, then turn key off iff led is off try alarm.
Sep 22, 2009 | Vehicle Parts & Accessories
Car doesnt start immeditately. security light comes on. once security light goes out car starts. Why?
it is detecting a problem....could be a dirty key or bad chip in the key....try this.....set the alarm by locking the door using the power lock switch and then close the door...the security light should come on steady for about 2 minutes and then go out.....the alarm is armed at this point.....you can unlock the drivers door using the key to reset the alarm.....if you do this with the windows down you can open the door from the inside to set the alarm off and see if it works properly by flashing lights and horn....after you trigger the alarm you will have to reset it by using the key on the drivers door....
Jul 04, 2009 | 1998 Buick Riviera
My gemini car alarm system has stopped responding to my key fobe, iv'e changed the battery in the fobe to no avail. The red light on the car alarm system dose not flash or show any signs of life, is there...
it may have some lose wirings thats why its not responding, try checking the cables or the connectors of the alarm. if its all intact then you may need an alarm replacement. hope this helps.
Jul 03, 2009 | 1998 Volkswagen Passat
ELECTRICAL MISTERY
Here's a first step: Put key in ignition, turn on but do not start car. When dash lights up, the alarm light will flash if it has been triggered. If this alarm light is flashing, you have set off the alarm. Here's how to reset it: Leave key on, and let the thing flash for five minutes or so. Finally it will stop flashing on its own. Now start the car. If it runs ok. Kill it and turn key back on to check if light has stopped its flashing. This may be way off, but that is the reset procedure for alarms on those blazers. Man I've seen a bunch of them in my shop this year!!!
Mar 20, 2009 | 1996 Chevrolet Blazer
Alarm has reactivated after being defunct for 4 years
The best way to solve this issue is simply sellling your vehicle!
Feb 09, 2009 | Hyundai Motor 1998 Accent
Canon pixma MP130 is not working
The cartridge seem to be jammed at the extreme right end of my machine. Pulled the ribbon to bring the cartridge slots to the centre. Then removed the cartridges. Unplug the power behind. After a minute, plug back the power. Load back the cartridges. Printer resumes back to working mode.
Jun 03, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
284 people viewed this question
old marine
old marine
