Question about Zebra QL320 + LCD U/L ZVR 802.11B DT/ LNRLSS [q3c-lufb0000-00] Thermal Printer
Zerba ql320 plus
Hi i am experiencing problems with my zebra ql320 printer. currently, i use a symbol mc70 handheld paired by bluetooth with a zebra ql320 plus printer. i am experiencing the following error 'service connection error' on two occasions: 1) printer print information and the above error appears 2) you can print a couple of times and then it won't print at all. sometimes turning off the printer and on again works or turn off bluetooth on the handheld and then reconnecting the equipment allows information to be printed buut then the errors keeps coming up. can you help with the connection error?
5 Suggested Answers
  • 185 Answers
SOURCE: zebra QL320 plus no bluetooth discovery
Turn the printer up side down and remove the battery. Undo the philips screw and remove the module from the top. re-seat it back on the main PCB and replace the screw and battery. if the module still doesn't work then it is more than likely it has failed.
Posted on Apr 13, 2010
SOURCE: How can we change from black bar sensor printing
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
Posted on Dec 23, 2010
  • 135 Answers
SOURCE: How ot change the font
Contact Zebra Technical Support Phone: +1 877 275 9327
Fax: +1 847 913 2578
Kiosk Only: +1 866 322 5202
**Best Option will be to call them since it is a mobile printer**
Posted on Mar 10, 2011
SOURCE: How to calibrate the label in QL320 plus zebra
create a text file called Calibrate.txt and in the text file type this:
~JC
^XA
^JUS
^XZ
then send the file to the printer using label vista.
this will then print 3 - 4 labels and stop.
once u press the feed button it will only feed one label.
Posted on Apr 05, 2011
Testimonial: "Thanks"
How ot change the font size, printed on QL320 plus Zebra printer
Mar 10, 2011 | Zebra QL 320 Thermal Printer
How to calibrate the label in QL320 plus zebra printer?How to make it only feed 1 label per print?
~JC
^XA
^JUS
^XZ
Dec 10, 2010 | Zebra QL 320 Thermal Printer
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
^XA ^JUS ^XZ
Nov 03, 2010 | Zebra QL 320 Thermal Printer
Our company has several Zebra printers that print out barcodes that are scanned using handheld scanners for many things including inventory management. The labels that come from ONE of these Zebras...
Power off printer. Press and hold pause button while power on. This will print dark black line across the entire label. Check for white vertical lines. If you see any in the area of the label where you are experiencing a problem then the printhead should be replaced. Power off and on to exit diagnostics.
Jun 25, 2010 | Zebra 105SL Thermal Label Printer
Low battery life
Hello, did you turn off the bluetooth? have you changed your back light settings? If you want you can give me a call or send me an e-mail and i can walk you through the settings.
kganoe@datexcorp.com
800.933.2839 x251
Feb 19, 2010 | Symbol MC70
Zebra QL320 plus no bluetooth discovery
Feb 12, 2010 | Zebra QL 320 Plus Thermal Printer
Powers down after every print
There is a setting in the all CPCL based Zebra mobile printers called "DTR Power Off". You will need to turn disable this. It sounds like you are printing through the serial connection based on your brief issue description.
Connect to the printer with serial cable and run the Label Vista application, free from Zebra.com. If your printer is a Q3C or Q3D configuration, you can connect with a mini USB cable, but you will have to install the driver. If you have a Q3A or Q3B configuration, you must to use the serial cable (PN: BL11757-001) to connect to your PC.
Once in Lavel Vista, click on the Printer drop down and choose the COMM Port Settings option. Select the correct value for your connection type. Next, select Printer Settings from the Printer drop down. Go over to the Port tab and click the disable button under the DTR Power Off section. Click apply. If this does not work, also check your inactivity timeout setting as well as your battery level setting in the batery tab od the same screen. I set mine to "0" because I dont want my printer turing itself off for any reason.
Apr 04, 2009 | Zebra QL320-Plus Mobile Printers QL320...
Can't connect via Bluetooth connection problem
print a configuration label from the printer to get the BT settings, you may need to use "label vista"(zebra) to configure it. the keys are generated based of the BT mac
Sep 15, 2007 | Zebra QL 420 Thermal Label Printer
Zebra QL320 + LCD U/L ZVR 802.11B DT/ LNRLSS [q3c-lufb0000-00] Thermal Printer Logo
122 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
