Question about Olympus Cameras
How do I copy pictures from my Opympus master 2 to a CD?tfware!
    Scholar:
  • 75 Answers
Two steps:
1. Transfer to a PC or Mac by connecting the camera to your system (usually via USB cable), or use a card reader to transfer them.
2. Create a CD using your system software, or another app (suggest: Kodak EasyShare software which makes it easy to transfer the pictures to your PC, organize them, edit, then burn a CD). Most PCs come with software to support the burner you have on that system.
Good luck.
DigiChick
Posted on Jun 09, 2008
Opympus fe310,, will not download pics to pc
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Sep 12, 2013 | Vivitar ViviCam 5100 Digital Camera
Tip
I am also having the same problem...when I copy my pics from my computer to the...
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
on May 23, 2009 | Philips Magnavox DVD/VCR Dual Player
Olympus master 2 disk does not load down from tray; needed is to install Olympus vr-310 camera disk in-order to move pictures from camera to computer file, say disk D or E; could you provide?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 05, 2012 | Cameras
Iam trying to transfer my pictures from my FE230 to the computer. I installed the Olympus Master 2 software, yet when I plug in my camera it says i need to install the software and put in the disc. I put...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 10, 2011 | Olympus FE-230 Digital Camera
If I want to record let's say someone speaking for 90 min and burn 2 cd's , one 60min and the other 30 min from the one 90min recording , each one divided into tracks , how would I do this ?
If you want to burn a CD you have to make a master. For 2 cd's you have to make 2 masters, one for each recording.
The best way to handle this is to "create a song" for each speech giver and give each a name.This is because you can make only one master copy of a song before burning a Cd.
But another way is to :
1. Make a master of the first speech giver (who is on one track) and record to the Cd.
2. Make a new master of the second speech giver (on the other track) and record to Cd.
As long as you don't mind, the second mastering will overwrite the first one that you did, but then you already have burned a copy of that Cd!
Nov 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
I have Print Master Platinum 15- 5 CDs only - no paperwork
The install is pretty straight forward. Just start with disc one or disc labeled install cd (or similar) The manual is just guidance and not needed unless you prefer to reference to it. If you do need it you can visit the support section of the Print Master website to download a new copy.
Thanks Live-Tech 1-888-361-8511
http://www.mylive-tech.com
Jan 29, 2010 | Broderbund PrintMaster Platinum 15 Full...
When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
May 27, 2009 | LG 1 to 6 Target CD Duplicator 52x CDRW...
CD burner adding pauses
the programme you use to burn the cd's is obviously set to leave a pause between tracks, check the programme settings before you allow it to burn the music cd
Oct 07, 2008 | Acer Condre CD-Tracer Pro Tower 7 Drive...
Problem copying pictures to cd
Try burning the CD by using a different software, like Nero or CloneCD...
Please rate this solution.
Sep 20, 2008 | Microsoft Windows XP Professional With...
Master Software 2 help!
Ditto. Installing on XP w/SP1. Plenty of hard drive space. Pentium 4 w/2GB RAM. Tried different drives. Tried copying CD-ROM to hard drive to verify it was reading of the CD ok. No problem copying but still failing on installation. I also tried by-passing the initial Olympus menu and launching the .msi directly, but that fails in the same way. I haven't found anything on the Olympus website about this, but note their website generates tons of Javascript errors which is not encouraging with respect to Olympus's attention to quality. (This is my first and probably last Olympus.)
Tried pulling the XD media and reading it on the computer but my computer wanted to format the thing (never seen that with SD or Compact Flash, what gives?) so that was a no for the moment.
Finally, I went to the files that I had copied from the CD to my hard drive and double-clicked the OM2_Pack_Framework_2_0_4.cab file found in the OLYMPUS\OLYMPUS Master 2 directory. That contains a bunch of .cab files, that I extracted to another directory. In there, I found a application.cab, which I then extracted to yet another directory. In there, I found OLYMPUS Master.exe. That ran fine when I double clicked on it, but I still had the problem of not being able to read the XD directly, so I hooked the USB up to the camera with the XD back in the camera and was able to transfer the images in that manner.
Apr 25, 2008 | Cameras
Cameras Logo
48 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
