Question about GE (PSS26MSRSS) Side by Side Refrigerator
Side by side Sub Zero not cold enough.
Older side by side refrigerator. Freezer side still makes and keeps ice but ice cream is "soft". Frig side is only "ok"--milk is not very cold and tends to sour too soon.
  • loriwolter Jul 28, 2008
    Exact same problem with Sub Zero side by side freezer makes and keeps ice but ice cream soft and refrigerator side is not keeping cold enough Milk gets sour after couple days. I see a solution of cleaning the coils, is this something I can do myself or have to have someone do?
  • ACME Sub Zero Refrigerator Freezer
    What is the model of this SubZero fridge?
  • 37 Answers
I have the same problem with the same older model, and have kept the coils clean. I've reached the clockwise limit of the freezer control. I wish the answer were that simple. I'm hoping that the oppressive heat and humidity here (Louisiana) might be a contributing factor, but that might be just a dream, and I'll have to shell out for repairs. Still cheaper than replacing it though.
Posted on Aug 09, 2008
  • Painter33 Jan 17, 2009
    I cleaned the coils regularly, but at 24 yo, it's given up the ghost, so says three Sub-Zero repairmen - too many worn out parts and some have been replaced more than once.  We have an additional leaking problem and each person independently said it couldn't be repaired, so we have to buy a new refrigerator.  Because it's 48" it will cost a lot, too much really, but aside from closing in the built-in space we'll just have to grit our teeth and spend $8,000 +.  We don't know which brand to go with yet, but we're looking at Thermador.  American Home Shield said they won't help and they wrote the contract on the SZ!  They have no definition for "normal wear and tear" even though they apply it quite liberally when they want to deny a claim.  Typical insurance scam.
    Scholar:
  • 110 Answers
Clean you condenser coils
Posted on Jun 13, 2008
2 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Posted on Jun 11, 2008
I have a 12 year old sub zero 590 side by side. The freezer is not working well.ice is fine but ice cream is very soft. Meats and others are not so hard either.
Jai,
If the ice is still frozen after any time the temp is below 32. But thats not cold enough as you know. Target temp in such a freezer is between +10 to 0 F inwhich ice cream is good and firm. BTW many restaurants and food pro's set and judge the freezer temp by the firmness of ice cream! A twelve year old Sub Z should not be having such problems and causes could be numerous. Lets talk about what you can do. This is a built in unit correct? Ok, get your step ladder and remove the cover above the doors and look for a dirty coil, a failed fan, or both. If the coil is dirty enough to restrict air flow or fan not blowing this IS a problem! One that will cause such problems and is my bet to whats going on.
Oct 13, 2013 | Refrigerators
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Hi, I got no Ice in the freezer, and the Ice Cream is not hard
the higher the # the colder the frig should be . / if ice cream is not hard the freezer is not cold ennogh . so clean the coiles and ck the two fans . also look in back of freezer side for ice build up there should not be any frost on back wall . if so you've found the problem . which is a defros problem .. mm
Jul 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cream in freezer of our side by side refrigerator is soft
Try cleaning the condenser coil. It will be under or on the back of your frig. Use a vacuum cleaner attachment. Good luck
Sep 08, 2009 | GE GTS22KBP Top Freezer Refrigerator
I have a GE side by side refrigerator GSH22JST and frig is cold but freezer is not cold enough (soft ice cream)...heavy frost is building up on bottom half of evaporator. I can force defrost mode through...
Okay,
What is your Freezer temp rating?
Did you check the refrigerant PSI rating?
Is your condenser restricted?
Let try adjust refrigerator to less cold and adjust more cold for freezer. and see what your temp rating.
nguyen@ite.net
Jun 09, 2009 | Refrigerators
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Jun 11, 2008 | Refrigerators
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
564 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
