Question about Acer AL1715 17" LCD Monitor
OSD popping up
Hi there
I'm just wondering if you were able to find a solution to fixing the OSD problem
on your AL1715 monitor
mine is driving me
thanks in advance
  • 558 Answers
Well most osd problems are occuring due to corruption of the rom chip that holds the data you can flash the data back but... not my fav thin gto do.
a nre video board will be your best course.
Posted on Mar 24, 2009
Hello it means that the on On Screen Display is locked...more below.
Hope this helps
What does OSD Locked mean
Feb 20, 2014 | Acer AL1715 (Black, Silver) 17" LCD...
My monitor is eperiencing OSD locked and it keeps on popping out the screen. how do i fix it?
Hi rimandopaolo,
I see that you are getting the OSD locked pop up on your screen.
Press the Menu button on your LCD monitor look for the OSD option on the menu once pressed selct the OSD option try to see if it will give you an option to unlock the OSD setting on your LCD monitor
I hope this helps.
Have a nice day,
May 11, 2011 | Hannspree HW191D LCD Monitor
How do you get a osd lock out pop up fixed?
hi i have HP F2105 monitor. "OSD lock out" pops every 5 sec. what shoud i do? plz help
Oct 18, 2010 | HP Computers & Internet
Why does my Acer monitor display OSD LOCKOUT whenever I start up?
hold the power button for a few seconds it should say osd unlocked.... if that doesn't work unplug the monitor for a minute or so and plug it back in.. that should fix it
Mar 01, 2009 | Acer AL1715 (Black, Silver) 17" LCD...
My monitor say to me osd lockout.. can you help me? please
Hold the MENU button for ten seconds to unlock or lock the OSD.
Nov 29, 2008 | HP w1907 LCD Monitor
OSD Lockout
Have you opened the monitor's onboard menu and checked the OSD settings? Do that and see if you can change those settings there. I would also open the Device Manager and check for problems. If you see any yellow question marks, that hardware has a problem.
Sep 12, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
OSD problem on my Acer AL1715 17 in.
I had a simalar problem with my Dell 2001FP. The issue is that there is false triggering of the switch; you need to open the front panel, and remove the swictch from the circuit by: 1) analyze the circuitl; its usally pretty simple - a voltage drop circuit. 2) disable the switch by either removing it with a solder gun or, simply by using a sharp blade and cutting the PCB track leading it to it, as I did.(much easier - and reversible!) Fixed my problem.
Apr 15, 2007 | Acer AL1715 17" LCD Monitor
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic interfered with the plug and so the plug did not seat properly. I fixed several of these monitors by shaving off some of the plastic with a dremel mototool. A hand file would probably work as well. You have to remove the plastic back to do the job.
Sep 02, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
