Question about HP LaserJet 5si Printer
My Laserjet 5SI printer has been jamming a lot lately and now it's making a grinding noise. Should I replace the cartridge or what?
  • 374 Answers
Fusers generally make grinding noises more than cartridges do. If your paper jams are in the fuser area, check the fuser first.
When you open the left side door of the printer, the fuser is installed on a shelf near the top of the cavity. To remove the fuser, grasp the left and right blue fuser release handles and rotate them to the straight up and down (vertical position. Then lift up on the fuser and remove it from the printer.
Take a close look a the at the gear located on the top left corner of the fuser - does it have broken/ bent teet or is it loose on its mounting shaft? If so, that's probably causing both the paper lams and the grinding.
Also look in the printer directly under where this gear would be if the fuser were inserted in the pinter. Do tou see a build-up of fine particles the same color as the fuser gear. If you do that's further proof the the gear is bad.
You can but a replacement fuser at several places - check out www.printerworks.com & you can get one on an exchange basis.
Posted on Oct 27, 2010
Testimonial: "I did what you said and the fuser is the problem. I really appreciate your help. And your QUICK response! "
  • tranhoaithu Aug 13, 2011
    May be a small piece of plastic piece broken from the rolling assembly under the cartridge Pull out the cartridge, examining carefully and reinstall it...
My hp laserjet m1522nf makes a grinding noise and then says add paper' it also makes the same noise when i shut it down and power it up again ... does this mean the printer is garbage?
it could be a bad toner cartridge
try replacing each toner cartridge one by one to see if grinding gear noise goes away.
Or
it could be jammed paper somewhere inside the printer
Feb 03, 2017 | HP Laserjet M1522nf All-in-one Laser...
What the part no for main motor assy. The whole assy that needs to be replaced due to unusual grinding noise during paper run.
You cannot typically buy the entire assembly as one piece. You need to purchase the main motor and then all the related gears. There are companies out there that sell a kit with all the gears, look for one for the 5200 laserjet as they are the same.
Aug 31, 2016 | HP LaserJet M5025 MFP Printer
Is this thing shot for good?
Did you remove the new cartridge to make sure it isn't a paper jam and also to get a better look at the interior?
Aug 23, 2014 | HP LaserJet 1020 Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
Hp laserjet 5200 grinding noise from left side
front, rear ? I'd say fuser assembly gears or drum on toner cartridge; check the gear teeth on the toner cartridge's drum.
Dec 20, 2012 | HP LaserJet 5200 Printer
My HP Laserjet 2430dn makes a grinding noise after power on.
CHECK RS PRINTER PARTS FOR HP LASERJET 2400 2420 2430 PRINTER GEAR KIT
Feb 26, 2009 | HP Office Equipment & Supplies
My hp printer 5610 all-in-one does not turn on. What to do?
whenever i press the 'on' button, my printer doesn't respond.
Jan 13, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Laserjet 4L - Grinding or Growling noise when job sent to printer
goto feedroller.com
http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
purchase a maintenance kit.
replace the piper pickup roller.
since the the printer is old and lots things need to be replaced. it is easier to replace all of the necessary parts when you have the printer apart.
the job is not difficult, just time consuming.
Nov 02, 2008 | HP LaserJet 4L Printer
HP LaserJet 5si Printer Logo
168 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
