Question about Bosch Washing Machines
Washing machine brushes
I have removed my old brushes...Bought New ones and now cant get them to fit in ...........Please help
    Novelist:
    Champion:
  • 244 Answers
What make of washer is it
Posted on Jun 10, 2008
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
Oct 04, 2014 | Bosch Washing Machines
Will not spin
what make is the mach you say you have changed the brushes and they were fitted correctly?were the old brushes worn out does the armature look ok were there any signs of arcing on the old brushes is the field coils ok could be the motor or the pcb depends on make etc sorry cant help you more make sure the brushes are seated correctly hope this helps
May 06, 2014 | Washing Machines
My Zanussi nexus fl881 wont spin. Can you tell me how old this washing machine is and how to fix/whether to get new one?
6/8 years old.....Souynds like new motor brush kit needed. price of parts about £30. plus labour possible 30 mins work to fit..Hope this helps
Apr 01, 2011 | Zanussi F1045W Front Load Washer
I have a hotpoint wd420. the door light is flashing the wash light is on constant and the machine wont work anyone any solutions please!!
My WD 420 packed up, after watching the blogs I did:1) remove filter - found 2 quid, a thong, a pop sock, a christmas cracker toy and a load of gunge. 2) removed the motor - brushes worn to nothing - replaced them.
Washer running as new. 6 years old, 2 house moves - not bad reliability. Nearly gave up and bought a new machine!!
Nov 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Fit the burshs in a bosch machine
Tilt washer sideways to gain access to motor. You will see brush holder modules (2 of them). Each has 2 screws holding it into place.as you remove one, replace it exactly the same way. Once installed, run machine. Cant explain how to embed brushes, so test full cycle without a load.
Sep 16, 2009 | Bosch Washing Machines
Fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
HO DO YOU FIT BRUSHES TO A WFR2866GB WASHING MASHINE
remove motor,
remove motor brush cover screws from the motor
shake out old brushes
insert new brushes, spring side out
install brush cover screws
install motor
Sep 27, 2008 | Bosch Washing Machines
Hotpoint wma57
the filter is at the back where it enters the machine undo the cover you will see a big black tube clipped in a few places undo and the filter is inside there
May 14, 2008 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
