Question about Cell Phones
Recharge slot is broken. When I try to recharge my phone, there is no sign of recharging. I tried with two different rechargers but it is not working. Any ideas?
U can change recharging socket but it need skill & soldering gun etc ,some cdma mobile have alternateive socket such as lg 2330 6130 2230 etc
Posted on Jun 09, 2008
I charged my KX-TGA652, it keeps saying use rechargeable battery. Does not seem to hold charge
It does take rechargeable batteries. Remove the back and change batteries for Ni-cad or similar rechargeable batteries. Trying to recharge normal batteries is dangerous. Any rechargeable make of battery will normally work and they recharge when phone is in cradle
Feb 21, 2015 | Panasonic KX-TGA652B Cordless Phone 2 Pack
Does the garmin need a ion battery to work?
jon battery is inside, may have flat charge, try recharge waiting more;
jon battery protection recharging circuit, may be broken or battery pack loose minimum voltage to be recharged, about 2,5 volts.
SAFETY recharge range of jon batt. is 2,8 to 4,15 volts.
Apr 23, 2014 | Garmin NUVI 360 GPS Receiver
My phone wont charge
there could be many reasons for such a problem, charger related , and device related, so you have to check the following:
-first, you should check the power socket, it might be the reason why the charger is not charging your mobile phone.. try to insert it to many several power supply sockets..
-second if you tested it and it did not work; the charger itself might be broken, try to attach it to another mobile phone and see if it will charge or not, and try another charger to be attached to your mobile phone so that you will figure out if the charger is broken or not..
-third, assuming the charger is perfectly functioning, it is more likely that the battery is dead, every rechargeable battery comes to an end someday not able to be recharged having its chemicals consumed or changed, so that the easier way is to be replaced.. BUT, if you put that battery in a similar compatible mobile phone then tried to recharge it and found out that it is been recharged successfully, that means one thing that the charging port (where you connect your device with charger) is malfunctioning or broken so that it does not joint the charger with the battery..
Mar 26, 2011 | Cell Phones
My screen is dark. I have tried recharging the
Does the phone turn on (does it play the sounds)? If not, and it's completely dead, try a different battery and charge, if that fails it seems like you have a broken logic board. Somebody needs to open your blackberry to replace it. Go to your provider, they might replace the phone for you. If they refuse and If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is a Blackberry Bold Repair Guide that shows how.
Jun 05, 2010 | RIM BlackBerry Storm 9530 Smartphone
Batteries will not recharge on stand. Have used different rechargeable batteries but same result
It could be the metal contacts that's used for recharging the mouse that isn't making a proper connection. The most common cause for this, would be dirt & oil that would build up on the charging contacts over time.
I would try to clean the contacts with a dry tissue paper on both the mouse and the charging stand and see if the mouse will charge properly again.
If that doesn't work, then maybe it's just the recharging circuit inside the mouse that's broken.
Jun 03, 2010 | Logitech Cordless Mouse
Nokia phone not recharging
Technically, It would be an old battery issue, or the charger itself, try using another charger, if the problem still occurs, maybe it's the battery or your's phone's charger jack had a hardware issue.
Feb 10, 2010 | Nokia Lands Phones
Samsung sgh p310 wont charge
check to make sure it is connected properly and whether the pins in the phone's charging slot are not broken, because I have a samsung SGH-D807 and I forced the charger in the slot and the pins got broken, it won't charge. I have to repair it.
so connect it properly and check to see if the pins are broken, if not, try another power socket to plug the charger in, not all sockets are compatible with a charger.
Dec 13, 2008 | Samsung SGH-P310 Cellular Phone
Failed recharging of cell
im faozen in limpopo.as technition recoment that you take your cellphone for repairs to clean via flux chemical,because most of this problerms are cause by water damage or vapour from human body call me at 078 218 6916
Mar 03, 2008 | Motorola Mobility RAZR V3
Cell Phones Logo
66 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
