Question about Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-M430 The optic lens has fallen out... I see where it goes... How do I attach it back? or do I? Thanks Brad
  • bradley t Jun 10, 2008
    Hey Duncan, I had already had done what you had told me....But I backed up and regrouped, checked alignment the best I(eye) could and wallah! it works it is slightly touchy but touchy vs throwing out works for me Thanks for your help!
    Brad
    Novelist:
    Champion:
  • 218 Answers
If you can't put it back then the laser unit is no good anyway so it may be worth a try. I would not recomend super glue because it outgasses a substance that may cloud the lens. (that is how they use super glue to get finger prints from objects) Maybe use a thin film (very thin film) of rubber cement very carefully applied to the edge of the lens would do the trick. You must act fast because rubber cement cures so very fast. Another possible glue would be epoxy. It would give you a little more time before it starts to set up. Be sure you have the correct side up when you attach the lens, and be SURE that it is well seated in its socket so that you don't screw up the focus of the laser. Do a dry run or two with no glue to get the feel of what it takes. Don't forget to clean the "inside" side of the lens before you glue it in. You can clean the outside once it is glued in place. If all else fails you still are in a situation where you have to change out the laser assembly. Nothing ventured, nothing gained. Good luck.
Posted on Jun 10, 2008
I have a pioneer model pd-m430 6-disc multi-playcd that won't play. it lights up when you turn it on but no sound. it some times channel through the discs but does not play
It sounds that the opticla pickup unit has the fault. Clean it and check. If this do not help you, replace it.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Jun 03, 2012 | Audio Players & Recorders
I have a PD-M430 that has always worked and now it does not Is ther just a two wire hook up involved are am I missing something
your right just a left and right output to your reciever is all thats needed --of course the a/c power cord as well---if still no sound maybe your reciever settings have been set to turn off your cd jacks in favor of an optical input?!
Sep 04, 2010 | Pioneer PDM435
Changer works but display reads no disc
the lens on the optical pickup is dirty and needs cleaning. they sell a lens cleaner disk at any electronics store. you also might want to blow any dust out of the unit with canned air to prevent it from happening again.
Dec 17, 2009 | Pioneer PD-M603 6-Disc CD Changer
Have a pioneer cd player model number PD-Z560T. Has started making my cd's jump while i'm playing them.Have tryed cd lens laser cleaning disc but still no good any ideas?
My cd unit on the pioneer pd-z560t also jumps. I also tried lens cleaner, with no luck.
It was suggested to me that cleaner is only any good for a good - but dirty - lens, but no good if the lens has actually deteriorated and become weak.
I would be curious to know how a lens could actually deteriorate pls.
plese try to reply to: clerical@live.co.uk
Thanks
Andy
Nov 01, 2009 | Audio Players & Recorders
Getting 'no disc'
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc', code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 25, 2009 | Pioneer PD-F1007 301-Disc CD Changer
No Disc Light
HI, the Optical lens assembly has failed. either the attached motor has failed or, the lens has burned out.
this assembly will need to be replaced as a whole by the manufacturer in this case. the replacement parts are not available for consumer purchase.
Contact pioneer for a repair ticket asap.
Feb 02, 2009 | Pioneer PD-F1007 301-Disc CD Changer
The 6-CD magazine will not eject from my Pioneer PD-M430 player. The 2nd-slot seems to be stuck. Is there any chance I can remedy this myself?
hello of course you can do it only you need a bit of precaution check this in magazine look for broken/deformed little piece of plastic especially in 2nd slot if it is ok next step look inside check again in the room where you put the magazine and it has a small coils check the 2nd i hope yu find the solution my best luck.........saludos
Nov 25, 2008 | Pioneer Audio Players & Recorders
Pd-m403 cd player skips thru all six cds (they are oriented correctly) without playing any selection, then get a message "no disc"
Hi there
Sure you can.for 12 years I was a prefferred service agent for Pioneer. I have repaired dozens of these units with this problem. It has been happening since they came up with the six disc changer mech. The Pioneer preferred way is to replace the optic, set the diffraction grating(not an easy task without the right gear) and mechanical alignment of the new optics. DO NOT USE CYNOACRYLATE BASED GLUES This is super glue. the fumes will cloud the lens and render it useless, I use Tarzan's Grip, a clear general purpose repair glue,used for say china,metal plastic etc.
  • I always make sure that the lens in orientated the same way as it came out. You can usually tell by the glue marks on the sides of the lens and the holder it seats into.
  • Refit the lens, then dab the sides of it and the holder, don't get too carried away.
  • I use at least 3-4 dabs about the sides of the lens, but don't put it under the lens before you seat it .
  • I then put something on top of it for at least 12 hours till the glue sets. then hopefully if all went as planned, it should again work.
I used to always check focal offset and tracking offsets, and tweak also the RF pattern to refocus the repaired assembly. You do need test gear to do that, but generally, the player will work if the lens is seated correctly and secured properly. Happy to talk to you more about my experience doing this job,or answer any questions about it.
regards
robotek
Nov 14, 2008 | Pioneer Audio Players & Recorders
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
Pioneer PD-M426 6-Disc CD Changer Logo
765 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
