Question about Belkin (F5D7231-4) Wireless Router
Rookie attempting to connect two computers via router wireless
I have a belkin g + router given to me and seems to be set up correctly, purchased a linksys usb connected adapter they both seem be be connected but cannot access the internet.
To make sure its setup properly you should reset it up, to do this press the reset button on the back of router, and then when its up to a ready state acess it through your web browser. the adress is 192.168.2.1 ,then click the login button, the defualt password is blank. after that your are logged into the router you can run the setup wizard located on the left hand side of the page. once setup is complete you should be able to acess the internet.
Posted on Jun 09, 2008
Newly purchased Belkin Surf N300 wireless router. connected my wife's Windows 7 laptop just fine - quick and easy (in fact using it now). Went to connect my XP netbook - connects wirelessly to router...
There will be a lot of possible reasons on that, might be the wireless settings of your computer , you may try to remove all the old networks saved in your laptop and try connecting to it again,heres how 1. locate the wireless icon at the lower right hand corner of your laptop 2. Click on View available wireless settings 3. Click on Change advance Settings on the left side 4. You will have a small window with 3 tabs, one is general but just look for wireless tab 5. Box below you will see the list of the wireless name that was saved . 6. Delete everything, then make sure you apply it if there is or clicking on OK will do 7.Then try connecting again and make sure your password is correct.
or it might be your security application, try checking it and see if there's need to change especially if you got norton installed in your computer, try uninstalling and reinstalling it.
Jul 03, 2011 | Belkin Surf N300 Wireless N Router
Connect my office computer to belkin wireless
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Feb 06, 2010 | Belkin (F5D7230-4) Router (587009)
My Belkin wireless G router does not seem to work any more. If I connect my router to my DSL modem, I am not able to make a connection to the internet via the router to my iMac. However, if I connect the...
So if you connect the computer directly to the modem , it works .
That means your modem is working properly. Your ISP is DSL connection. Now connect the modem to the router and the computer to the router. Open the router xet up page and change the settings of the router according to the type of connection you have.
There are 2 types of connection in DSL.
DHCP and PPPOE .
Click Here for step by step instructions
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Having problems connecting a lap top computer to the internet.
Connect the router directly via lan to your computer.
goto setup of the router: usuallly via the ip-adress of your router (see manual, usually: 192.168. ***.*)
Now look at the network security-settings .
May 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Cannot connect to belkin N1 wireless router
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Apr 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I'm having problems going wireless
What process have you followed to try to connect to the network and access the Internet? Where does this process fail?
Apr 13, 2008 | Belkin (F5D7230-4) Router (587009)
I have purchased a Belkin Wireless G Router for a cable modem. I have installed however i am unable to see the wireless network. What have i done wrong ??
Hello experts....
My problem is not being able to work wirelessly with my laptop. My answers to your questions are underlined(I've used your questions to someone elses problem)
One possible issue is your router's wireless radio is not enabled- the light on the router is lite on the symbol for wireless
or the wireless radio is not enabled on the computer you are attempting to connect to the router with - there is a switch on the front of this machine which is switched to wireless.
There are many other possibilities as well. That is why we need you to carefully answer EACH ONE of the following questions.
(01) Which of the following is your router?
-->> F5D7230-4 (Wireless G Router)
(03) Are ANY of the computers connected to your Belkin router able to access the Internet?
YES
(04) If there are other computers connected to the router that are able to access the Internet, how are they connected? (in each case, please)
only this machine is connected but it is by....
(b) wired (using an Ethernet patch cable connected between the router and the computer)
(05) What is the manufacturer and model number of the computer you are attempting to access the Internet via the router on?
HP Pavilion dv2500
(06) What operating system is installed on the computer you are attempting to access the Internet via the router on?
This machine is operating on Vista but the internet access I have is with talktalk
(07) Have you ever successfully connected (wirelessly) to the Internet from the computer you are attempting to wirelessly access the Internet through your Belkin router on?
NO
I hope you don't mind me using your questions to someone else, I thought you might be able to figure out what I'm doing wrong. I am connected to the internet but don't seem to be able to work wirelessly. Lorraine
Apr 09, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin wireless G USB adaptor 802 11g
Correct installation of this cheap little piece of kit from Belkin might be the worst thing you ever do! If you find that Windows XP is freezing 10 times per day, just remove the wirelss adaptor and you will find that the problem disappears... The conclusion will be as obvious to you as to many other users.
Jul 13, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Belkin (F5D7231-4) Wireless Router Logo
67 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
