Question about Canon PowerShot SD850 IS Digital Camera
Canon SD 850 says lens error,
Cannon SD850 IS 2 months old. The lens will not close. When you turn on the camera it says lens error, restart camera
  • 7 more comments
  • Anonymous Jun 10, 2008
    Same problem--"lens error". I have had camera for 8 months.
  • pitchingkiow Jul 17, 2008
    my lens wont retract and when i turn it on, the screen reads lens error, restart camera. is there a reset button or something to get it to retract?
  • Barry Baker Aug 09, 2008
    The lens on my Canon 850 IS wont retract. Message says "Lens error. Restart camera". I have removed the battery - and the film card - but problem not resolved.
    H E L P!!
    Barry Baker
  • taramissu Aug 17, 2008
    my camera says lens repair
  • fixitCanon Aug 29, 2008
    Hi! I had the same problem.Twice I was able to fix it by tapping the body of the camera on my bed. No luck the third time. I sent it back to Canon and they wanted to charge me 134 dollars to fix it. I know I didn't do anything wrong! Clearly, Canon has a faulty product and will not stand behind it.
    If you have the same problem, I found two websites that are compiling people's complaints. Perhaps for evidence in a class action suit, perhaps to vent. You should add a note too!
    http://www.e18error.com/
    http://e18.bitnet.cx/
  • chops10 Sep 01, 2008
    Same problem for me.....no drop or anything like that. I used this camera Canon sd 850IS) about every day since I got it 9 months ago. Now it says "lens error, restart camera" and will not function.
  • soni786 Mar 27, 2009
  • brianjsykes Apr 03, 2009
    The SD850 is prone to this issue having researched this error. I as well have this issue with my SD850. I won't spend $100 on it because I can get a comparable camera for not that much more. Too bad Canon released such a faulty camera:( I won't by another Canon because of this.
  • Anonymous Apr 07, 2009
    I also get the "Lens error, restart camera" message when I turn on my Canon SD850 IS. Mine is already past the warranty, so I guess it's time to buy a new camera.
  • 36 Answers
There could be a number of reasons for the lens error. ie. . sand in camera, impact damage etc. Typically the lens can be dissasembled and repaired by a competent camera repair technician. If you are certain that you did not damage the camera in any way I would send it back to canon for a warranty repair. If you however think you could have damaged it you are probably looking at around $100 to repair the camera. Hope this helps!
Posted on Jun 10, 2008
I bought a canon SD 850IS before 15 months back and now i'm getting "LENS ERROR". I didnt damage by dropping down or handling roughly and also i didnt used much.when i start my camera it showing LENS ERROR.... Is there any way to fix this issue by my self or should i take to canon service center?
Please help me....
Thanks in Advance,
Srinivasan.G
Posted on Jun 19, 2008
The Canon SD 850 has a host of issues. I experienced the lens error on the 30th day of my owning the camera and was able to get a replacement. Then, the replacement, after using just 2 times, would not start or turn on. I sent to Canon and they refused to honor the warranty saying their was water damage. It sat on a dresser, in the box, and was used only twice. They refused to do anything in regards to their so called 1 year warranty and I did not get this camera wet or even near any type of moisture. If I did, I would acknowledge that fact. You can buy earlier versions of this camera and newer versions but you cannot find this camera anymore so Canon knows they had an issue but will not stand behind their warranty.
Posted on Aug 10, 2008
Cannon SD 600 lens error restart camera
Go to this website for the solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 26, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
The lens on my Cannon SD sure shot wil not close
Lens errors are fairly common for all digital cameras. Usually it's sand (be careful at the beach) or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
E 18 problem
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
Canon ixux
try newer batteries 1st see online if ther is firmware update for your cannon.com model camera try those 1st thx nick
Oct 06, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens will not close
Hi
Your camera is still under warranty, and what you are seeing is a generic message that means there is an error with the lens operation. Please call Canon and have them fix it for you for free!
For others who's cameras are not under warranty, you will need to have your lens repaired or replaced if you get the error messages mentioned above.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
We have your repair listed as a package in our store for about $70. This covers a new lens, and return shipping of your camera! We even give a 45 day warranty on parts and labor. If you think you can use us then please check us out, even if you need to ask more questions then please feel free to contact me.
Hope this helps,
Thomas
Darntoothysam com
Feb 23, 2008 | Canon PowerShot SD850 IS Digital Camera
Help please
I'm assuming you have a lens error which is giving you the restart message.
It is kind of misleading, but to restart the camera means to power cycle the camera or remove and reinsert the battery.
If you do have a lens error, if restarting the camera doesn't work, you'll need to get the lens fixed if to remove the error.
Dec 17, 2007 | Canon PowerShot SD600 Digital Camera
Lens will not close
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot SD850 IS Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
3,000 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
