Question about Maytag Neptune MAH5500B Front Load Washer
Won't spin Everything else works great on this machine, but it won't spin in the spin cycle. What do I need to do? I already replaced the drain pump, so that is all working fine. Model # is MAH4000AWW. neptune mah-1 washer . door won't lock so it won't go into the spin cycle..repairman replaced the circuit board ( 320.00 ) it worked for 3 0r 4 loads then the same thing...he put another circuitboard in...(warranty) and the same thing happened. now i can't get him back out to look into it farther....either defective boards or something causing it to short out the board
  • 3 more comments
  • buckyoh Jun 12, 2008
    thanks micbeth1981 !!! i suggested this to the service man aand you were right on the money !!!
  • speedyNajera Jul 28, 2008
    Our Maytag Neptune MAH4000AWW works fine, too, until the final spin cycle. At the end of the wash, the motor doesn't seem to spin fast enough to pull the excess water out of the clothes. When this last cycle is finished, there is still a little water at the bottom with the clothes. I have already replaced the water pump, and still have the problem.
  • debbielynne Jul 29, 2008
    I have the exact same problem as
    1 Other User Has The Same Problem
    Comment by speedyNajera, posted on Jul 28, 2008
    Last time I had this problem I googled and was told to use a wet vac and I cleaned all the hoses with it and it worked fine for about 3-4 months. I have a family of six so it gets a work out. I did the samething as last but it does not do the fast spin dry to get the water out.
  • bryton Jul 31, 2008
    We have a Magtag Neptune stackable. I don't know if that is the number. Our machine will not go into the spin cycle. We have changed the motor board and the wax motor and it still won't work. Any other suggestions? Lin Waddington
  • kimdragotta Sep 16, 2008
    Same thing, my machine is not holding water at the bottom but the clothes are still really wet. I took the hoses off and cleaned them and the pump which seems to be working. I saw on another web site that some people have replaced their 40 W with 80 W pump but don't know how to tell if my pump needs replacing. Any ideas?
    Genius:
  • 1,122 Answers
You need to replace the wax motor door latch as i have read all of them have to be updated due to defect,if you need more info let me know-mike
Posted on Jun 09, 2008
  • MIKE major Jun 12, 2008
    good job,please leave me good feedback on fixya-mike
Ntw4501xq0 washer won't spin
You have a bad lid switch and it will need to be replaced. Here is the part to order. Below is a video to show you how to replace the switch.
Jan 21, 2013 | Amana NTW4501XQ
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
Oct 08, 2012 | Asko W6021 Front Load Washer
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My washer won't spin on spin cycle
Hi rapwizz,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | Whirlpool Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
343 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
