Question about GE Heating & Cooling
I bought a GE Air Conditioner at Walmart yesterday, we installed it. When we turned it on to cool the house down,the compressor came on and made a high pitch sound. When the fan is on it does not make the sound. Just when the compressor comes on, Model# AEW10AJS1 AEW10AJS1
Does the high pitched sounded continue or does it just occur when you turn the compressor on. Does it go off? If so, how long does it take? Please email me at whd2@columbia.edu Thanks very much. Bill Depperman
Posted on Apr 18, 2009
  • 1,420 Answers
Tack it back, either lack of oil or it was stored upside-down.
Posted on Jun 09, 2008
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
The compressor is running but not cooling.
Try the following to begin operating the air conditioner: 1. Plug in the air conditioner. (To prevent electrical hazards, do not use an extension cord or an adapter plug.) 2. Set the exhaust vent to the CLOSED position. 3. Press “On/Off” button to turn unit on. 5. Press Mode “COOL” 6. Press “TEMP/TIME” up or down V to the desired set temperature. Review the “Air Conditioner Features” section for other settings
Jul 10, 2008 | Frigidaire FAS185N2 Air Conditioner
I bought an air conditioner and the plug does not match my plug It says it is 230/208 Voltage what can i do
What is your house voltage?
This machine should run on a dedicated circuit. Have one installed.
Alternatively, you could return the AC for a 110 VAC model.
Apr 11, 2011 | GE Built-In Room Air Heat Cool Air...
I moved apartments yesterday and installed the air conditioner into the new window and when I plugged it in it doesn't turn on (even after restarting it).
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Heating & Cooling
Not cooling
Take it back and exchange it before it is a month old,or it will be hell to do it,there is something wrong with the unit.
Jul 06, 2010 | Haier Mechanical Air Conditioner HWF05XC7
My AC starts fine. But the compressor will over heat and shut down in higher temperatures (high 80's lower 90's. It has run without issue on some days like yesterday with temps in the mid 80's. The...
Most likey cooling fins are plugged and also my need new compressor or low on refrigerant or refrigerant oil. Could also have plugged intake filters in the intake.
Jun 25, 2010 | Carrier 38CKC036 Air Conditioner
I has a split AC there is problem of electrical wiring between compressor and in house machine. I need some service center address in Ahmedabad city Gujarat to recify the same. My model No. is SAP-K184ML
hi,there is a problem commucating...possible one of the wires has gone bad....you will need to to turn off all power to both units at the breaker at the panel or disconnect...you will need to go to walmart purchase a electronic test meter..they have one for 20.00 ..i bought one yesterday...yiu will need to remove one wire at a time from the indoor unit...get a piece of paper befor removing any wires...mARK NUMBERS....
Mar 26, 2010 | Sanyo Split System Air Conditioner
Not cooling house. Its never worked.
Check and see if the inside and outside coils are cleaned , if they are , have someone come out and check the freon in the unit it can leak out over a period of time.
Jul 20, 2009 | Weather King 10PJA2501AH Air Conditioner
Will not cool
I bought the same unit yesterday and took it back today. Not sure what's wrong, I guess they are junky a/c's.
Jun 10, 2008 | Danby Portable Air Conditioner
Heating & Cooling Logo
217 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
