Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Randomly Fills Up & Spills Over
Our LXIH-3 Commercial Under Counter Dishwasher randomly fills up with water to the point that it will spill out and onto the floor. This typically will happen when it has not been used in a while & fills up while in the OFF mode.  We typically then turn it ON, let it cycle through the start up process, then turn it OFF like normal. The water drains out like it should, but then we will check it a couple days later & the inside will be full of water again. The place we bought it from suggests replacing the solenoid valve. Does anyone have any thoughts about this one?
  • Anonymous Mar 13, 2014
    Tank full, floats good, turn on it fills, heat coils come, stops filling when top float is contacted. Push start switch, pumps and conveyor turns on...2-3 seconds later it shuts off. Hit start again, runs 2-3 seconds stops.
    Scholar:
  • 68 Answers
If your unit fills with the power OFF, 99% of the time it is a bad fill solenoid, OR DEBRIS in the solenoid. But before replacing it, I recommend inspecting it.
The fill valve is in the front area behind the kick panel. It has a large brass cap with little notches on it. Turn off the water and inspect the valve for debris. If you take it apart slowly, and catch the plunger and spring, it is easy. The only trick is having a pair of channel locks big enough to remove the cap!
Good luck. Mike
Posted on Jun 09, 2008
Hobart LXIH dishwasher
You can add a small amount commercial dish soap to the wash chamber before pressing the wash button.
Apr 02, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Fridgidaire FDB1250REC dishwasher comes on, fills some water in bottom then cycle stops but can hear motor turning on and off, water will drain when I try to start cycle again.
This seems to be the "anti flood" device at the base of the washer is triggered due to water at the base of the washer. This safety device consists of a polystireene float and a micro switch that detects water leaks/spills and automatically puts the washer in pump out mode. You need to find the leak (hose or clamp)dry the base and rectifythe leak it before the washer works.
Mar 22, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How can I shut off the water supply to the dishwasher? It fills slowly with water from the top (while not running), and then water spills out over the kitchen floor. By pressing the 'Drain' button, the...
Most water supply lines are attached to the hot water supply under the kitchen sink. If not it may be accessible from the basement somewhere under where the dishwasher is located.
Regarding the issue with the dishwasher, the inlet water valve is no longer closing because of the limescale that has built up inside. That is why it fills on it's own even when it's off. Instead of replacing the dishwasher you could just replace the inlet water valve if you want to get a few more years out of it.
Feb 27, 2009 | Sears 24 in. 14181 Built-in Dishwasher
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
130 people viewed this question
Top Hobart Dishwashers Experts
Ricardo311
Level 1 Expert
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
