Question about RCA P60921 60" Rear Projection Television
RCA P60921 60 in. Rear
Can I just pull this part off the board? Is there a screw holding it in? (that I can't find?) I tried pulling it off...it just seem like it was attached somehow. Thanks or your help.
  • 4,234 Answers
The pins are soldered to the board. You must remove the solder and solder in the new one.
Dan
Posted on Jun 09, 2008
My lg kp215a fell from the table and the screen went white- Please help!!!!!!
Things You'll Need
  • Small Phillips screwdriver
  • Pry stick
  • Replacement flex cable
  • Turn the lg kp215a over, and push up on the battery latch to remove the battery. Pull out the SD card cover on the side of the phone, and push in on the SD card to remove it.
  • 2 Remove the four screws the were covered by the battery and the two screws at the top two corners of the phone. The top two screws may be covered with rubber stoppers that you can pull out.
  • 3 Place your pry stick underneath the back housing, and twist the stick to pop it up. Remove the back housing from the device.
  • 4 Remove two screws that are holding the control board in place. The first is located near the camera button on the side of the phone, the other is located just below the speaker.
  • 5 Place your pry stick under the control board, and pull it up to free the board. As you pull the board up, find the connector underneath the board, and use your pry stick to pop it loose, then remove the control board from the housing.
  • 6 Pull the soft plastic keyboard away from the housing.
  • 7 Remove the three small screws that hold the housing to the hinge mechanism. There are four screw holes and only three screws, since one of the holes is used for a screw on the control board, so make a note of which holes the three small screws come from. Pull the hinge housing away from the LCD housing once you remove the screws.
  • 8 Remove the six screws from around the outside of the LCD housing. You will have to slide the hinge mechanism down to access the sixth screw. Just remember to slide it back up once you are done. Place your pry stick between the two halves of the LCD, and pop the back piece off.
  • 9 Remove the defective flex cable, and replace it with your new cable.
  • 10 Reverse the disassembly instructions to get the phone back together again. Ensure that the cable is threaded through the slots in the LCD housing and the hinge housing. When you put the control board back into the rear housing, hold it at an angle first so that you can connect the cable to the control board.
  • Read more: How to Troubleshoot a Sprint Rumor Phone With a Blank White Screen ' eHow.com http://www.ehow.com/how_7469322_troubleshoot-phone-blank-white-screen.html#ixzz1P1mTQeF8
    Jun 12, 2011 | Cell Phones
    Remove and replace right rear turn signal bulb 94 suburban
    OPEN REAR DOORS, REAR LIGHTS HAVE 2 TORX HEAD SCREWS IN VEHICLE DOOR HINGE AREA. REMOVE SCREWS, WIGGLE & PULL OUT ON LIGHT ASSEMBLY. THERE IS A 4 WIRES PLUGGED INTO THE LIGHT BOARD. UNPLUG & REMOVE 2 HEX HEAD SCREWS TO REMOVE BOARD & LIGHTS ASSEMBLY. IF A NEW BULB DOESN'T FIX THE PROBLEM, NEW BOARDS ARE AVAILABLE AT THE PARTS STORE.
    Jan 16, 2011 | 1994 Chevrolet Suburban
    Rca tv is blurry
    2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
    May 06, 2010 | RCA P52926 52" Rear Projection Television
    Accessing the rear hatch brake light on a 1999 Ford Expedition
    There should be 2 screws holding the lenses on for the hatch light, remove those and cover comes off. The plate lights, access them under the rear bumper, they twist and pull out, then just pull the bulb out the connector. The running board light, under board, which will take the light assembly out, or a small flat head screwdriver, pop the lens off the top of board.
    Dec 27, 2009 | 1999 Ford Expedition
    The attachment point for the coax cable was pulled off-broken off
    You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
    Dec 03, 2009 | Sharp 27H-S60 TV
    How to remove screen on projection screen tv 56"rca model#p56926
    Remove the speaker cover on the front, it just pulls off. Pry each side a little at a time. There are 4 screws that hold the screen on. Remove them and the screen just lifts off. There are wires attached to the controls so, keep that in mind when lifting the screen.
    Aug 10, 2009 | RCA P52926 52" Rear Projection Television
    Gateway 610XL Disassembly
    take cover off top of base.- pry off
    remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
    two screws on back of base and then take off back cover.remove sheild cover.
    disconnect all cables. 4 screws hold power supply in.
    rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
    pull all cables out towards you.
    remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
    remove base from screen.
    take out screws on back of screen. carefully pry all around case to seperate.
    remove back, and then sheild. there are a few screws that hold it on.
    If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
    Nov 05, 2008 | Gateway Media Center 610XL PC Desktop
    Disassembly of gateway 610XL
    Nov 04, 2008 | Gateway Media Center 610XL (610XLMDIA) PC...
    Convergence IC replacement
    some have plastic clips that need to be pressed back to release the board. There should also be 6 screws holding the D board to its frame.
    Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
    Screen removal
    pop off the front cove were the speakers are grab each side just under the screen were it is seperated. and it will pull right off. then their are two screws holding it in place on the bottom corners. after screws are removed the screen slides up to unhook.
    Nov 06, 2007 | RCA P52937 52" Rear Projection Television
    RCA P60921 60" Rear Projection Television Logo
    82 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
