Question about GE Refrigerators
Ge refrigerator model# pss26mstdss ser# sl402295 water filter replacment # ?
SOURCE: Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Posted on Nov 12, 2007
SOURCE: No water from dispenser ice works fine
My water outlet was frozen and wouldn't let the water through. Turn the fridge off and let it thaw out if this is the case. Regards, Phil, Brisbane Australia
Posted on Jan 14, 2009
  • 531 Answers
SOURCE: smelly water dispensed from ge profile refrigerator
flush the water tank put a glass press for water and keep flushing on till smell gone
Posted on Mar 31, 2009
706Cajun
  • 34 Answers
SOURCE: Water from Ge profile refrigerator
The water filter for this refrigerator is optional. The GE part number is: WR97X0214, or one of the box stores also carries a universal filter. Just make sure it for a ¼ inch line. The water filter is located on the back side of your refrigerator, and will have to be pulled out from the wall. Use caution not to break the water line when pulling/rolling it out.
Posted on Apr 25, 2009
shinn8
  • 85 Answers
SOURCE: Does this model have a water filter?
It does not have one. You can get one that installs in-line in you water line to the refrigerator if you want one. Have a great day!
Posted on Jun 01, 2009
Want to replace water filter - does this model have a water filter?
Yes, this model uses a GE Water Filtration Plus type water filter.
Jan 20, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Replaced my GE double wide refrigerator SMARTWATER FILTER #GWF With a which is supposed to be better. Yet, the water stream has cut down to half. Do I need the adapter collar for this newer model? ...
I have exactly the same problem. Replaced my GWF filter with the "new improved" MWF filter and the same thing happened. Tried replacing the filter not once, but twice - same low water flow. If you install the bypass plug the water flow is normal, so don't bother checking for water restrictions, bad hoses, tanks etc.. My refridgerator is a GE Profile 26 cubic foot purchased in 2004. I'm afraid these MWF filters don't work well in older models.
Oct 07, 2010 | GE Replacement SmartWater Filter for GE...
Water dispenser not working
This could be that your water supply is not good , check to see if you have plenty of water pressure going to the dispencer, this is aproblem sometimes at the valve, also change your filters, and make sure all is clean, this is a good start, if this does not do it will have tocontnue to troubleshoot
Feb 04, 2010 | GE GSH25JFR Side by Side Refrigerator
Water dispenser
My filter is located on the inside of the refrigerator in the top right corner. It twists off and is easy to replace.
Jan 21, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water Filter Freezes
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Jul 20, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Jun 01, 2009 | Refrigerators
Water from Ge profile refrigerator tastes bad so does ice where can I find the filter? Model #TFH30PRT
Apr 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Sep 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
