Question about Maytag Washing Machines
MAYTAG LA612 - Loud screeching noise when trying to spin during rinse cycle. Stop machine and a burning smell (belt or motor?) with a little smoke proceeded. Where should I start? Thanks in advance
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
  • 3 Answers
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Posted on Oct 01, 2008
appldoctom
  • 311 Answers
SOURCE: maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Posted on Jan 04, 2009
jsrock516
  • 5911 Answers
SOURCE: screeching noise in maytag topload washer
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
Posted on Feb 28, 2009
It made a loud noise during spin cycle and started smoking
Doesn't sound good does it?
Smoke could be a burned and shredded belt. Worse, the motor is burned out.
Loud noise? Depends on what it sounded like. Could be the concrete balance weight hitting the cabinet. Could be the belt hitting the cabinet when it snapped.
You need a repair man to diagnose.
Aug 24, 2015 | Washing Machines
I have a maytag washing machine model A712, during the spin cycle there was loud screeching noises and burning smell. What could be the problem.
problem could be the gearcase or the motor, to find out remove the motor and turn it with your hands to hear any abnormal sounds coming out, and also try to smell the motor see if it has a burning smell
Oct 16, 2011 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Washer make noise doing spin cycle smell smoke make the power cord warm to touch
Thanks for choosing FixYa and welcome to the site Joe. Usually, if a washer makes noises during spinning, it means the drive basket is broken. Make sure your pulley's are not sticking and rubbing the belt. This causes the basket to be unstable during the spin cycle. As far as the smell of smoke, try checking the belt and make sure it is not worn or loose. Inspect the motor to check for noises, grinding, or smoke. Your transmission may be burning up. Usually, the cord will remain warm, but not hot. The washer may be working extra if a belt is sticking or during the spinning process. If you have any other questions Joe, just let me know. Thanks for using FixYa.
Mar 31, 2011 | Kenmore Washing Machines
I have a Maytag Topload Washer Moderl PAVT2448WW
it may need to replace the MAIN DRIVE BELT , before assuming it could be the motor, HOPE THIS HELPS , AJ
May 18, 2009 | Maytag PAV2300 Top Load Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
196 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
