HaroWikihttp://www.harowiki.com > serial-number
The Haro Serial number page will help you decode, or try to figure out the model of your Haro bike. The serial numbers change from the 90s, 2000, and so on.
Missing: ACAllHO1239 ‎' Show results with: ACAllHO1239
VIN is only for 'Vehicles' and is 'Vehicle Identification Number'. You are after the 'Serial Number'. Yes, the number you supplied is the model number.
The serial and model number for your dishwasher will be on a sticker when you open the dishwasher door. The sticker can be found on the side of the dishwasher door, the top of the dishwasher door, or on the inside edge of the dishwasher.
Different manufacturers place the serial number in different locations - usually along the frame somewhere (bottom rail on left or right side side, under seat, etc. If you can reply with year, make & model I can see If I can find exact location for you
Issue:
Where is the serial number located?
Solution:
Locate the serial number MX882
Locate the Serial Number
The serial number of the MX882 is located inside the printer, as shown below.
With the printer powered on, open the Paper Output Tray (A).
The above illustration shows a PIXMA MX870.
Lift the Scanning Unit (Cover) (B) and fix it with the Scanning Unit Support (C).
Wait until the print head carriage moves to the ink tank replacement position.
To the right of the print head carriage, inside the
printer, is a white sticker that is attached to a metal plate. The
serial number is located on the white sticker. Please see the
illustration below. The serial number starts with four letters and ends with five numbers, for example: ABCD01234.
Go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
and type in serial number. The first result shows you exact instructions for finding the number. This assumes that your model is a Pixma MP530 - the only 530 in the Pixma line that I could find. The content of that page appears below (illustrations will likely not appear properly):
The serial number of the PIXMA MP530 is located inside the printer, as shown below.
Lift the Scanning Unit (Printer Cover) until it locks into place.
When the printer is powered on and the Scanning Unit is lifted, the Paper Output Tray will open automatically. If the Paper Output Tray does not open after several seconds, press the Open button to open the tray manually.
Open the Inner Cover. The serial number is attached to the back wall inside the printer. It starts with four letters (AAGA) and ends with five numbers. Example: AAGA01234
Please post back if you need additional assistance, otherwise thank you for using and rating FixYa!
