Zenith 52 in. m52w56lcd, hdtv monitor lcd projection
Color is a blue green huge. Can not adjust or get a pure white color. orange intdictor lamp on. What are all parts to be replaced. Thanks
Slinteriors
  • 8617 Answers
SOURCE: 1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Posted on Apr 10, 2008
SOURCE: my zenith hdtv model#m52w56lcd has a green tint.
Go to the Zenith web site. If you have not adjusted any of the default settings for color, brightness etc then a possibility is that your light engine is failing. Just this month a Class action settlement was put in place that entitles owners of this and several other models to have the light engine replaced in home under an extended warranty until July 2010. You should be able to find a toll free number if you follow the link to Class Action Settlement. I did and a service tech is coming to my house next week to replace it at no cost to me. I looked and the parts alone are approx 600 to 1500 bucks. Good Luck!!
Posted on Feb 26, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
techman007
  • 1112 Answers
SOURCE: Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Posted on Sep 25, 2009
  • 336 Answers
SOURCE: How do I reset the lamp hour meter after replacing
Hi,press the menu button on the front panel
while holding button on panel press and hold the menu button on the remote control
service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
press ok on remote
and now lamp hour is reset
good luck with it and God bless!
Posted on Nov 03, 2009
Testimonial: "Thank you so much for this very necessary piece of information."
I have a zenith M52W56LCD that has all green screen, what does this mean?
We have also had this problem before, you need to replace the color wheel. It is fairly simple to replace, just buy one and place it where the old one was.
Feb 17, 2013 | Zenith 5D6871VSMANZA001 Light Engine...
The color is distorted and the picture blinks. I've replaced the lamp twice before and i don't think this is a lamp problem.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Toshiba 52HM95 52" HDTV Projection...
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
May 17, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Picture is bowed reg green and blue lines on top of monitor.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
Feb 02, 2010 | RCA R52WM24 52" HDTV Projection Television
Converge off a little and screen has green tint
If you have the remote, go to the setup screen and move the picture. Converge has nothing to do with where the picture sits but, where the red, blue & green dots land. All you should see are pure white dots. There should be absolutely NO color ghost anywhere on the screen. If so, you need a bar / dot generator to set the convergence to center the dots.
Jan 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a M52W56LCD zenith 52" tv turned blue
Go to the Zenith web site and find the link for Class Action lawsuit. LG/Zenith will pay for in home replacement of the light engine which may be your problem. There is an 800 number on the site to call.
Jan 05, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith M52W56LCD picture is turning green.
The light engine on your set is burned out.
This is a very complex replacement.
I hope your tv is under warranty repair cause it is expensive.
It happens because the heat from he lamp over time burns out the lcd's that create th ed and blue leaving the gren which is always furthest from the lightbulb (YOUR tv has four lcd's in a row..red, blue, gren and then black.
If you wish to try and replace it yourself there are places online where you can buy a replacement engine.
Dec 13, 2008 | Televison & Video
Orange projection lamp on. Picture is a bluish green, no true white.
If you are in warranty contact Lg electronics since they own Zenith. I was having similar difficulties and they are sending me a replacement tv even though I am out of warranty by 3 years.
Jun 09, 2008 | Zenith D52WLCD 52" Rear Projection...
Yellow circle
The huge yellow circle is either your blue filter is burnt out (very common in Zenith DLP) or you LCD cube is bad. I would bet it is the blue filter. Zeniths DLPs have 3 color filters one blue (a pinkish color), one green (a grayish brown)and one red (it is red). For the bulb indicator I would check and make sure your lamp is seated to the ballast correctly. Just take it out and put it back in.
Mar 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith model #m52w56lcd tv?
For a really good step by step with pictures guide to replace it go to
http://www.fixyourdlp.com/blog/?p=34
For a good place to purchase the lamp go to http://www.discount-merchant.com/Original-Zenith-Projection-LCD-TV-Replacement-Lamp-p
/zenith_m52w56lcd_lamp.htm
I have found they have the best price on these replacement lamps. You might also check Ebay.
Feb 21, 2008 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
