Question about GE WBSE2090A Top Load Washer
Won't spin I have a GE WPSQ4160T top loading washer. It always made am incredible racket when it was in the spin cycle, now the motor seems to be running but no spinning occurs. I thought it must be a fanbelt but I can't figure out how to open the damn thing. It seems sealed on all sides. Does the front come off? That seems the most likely, but I don't want to break it.
  • 975 Answers
Yes !! carefully with a flat screwdriver open the front panel, its snaps , hope it helps AJ
Posted on Jun 09, 2008
GE washer won't spin
Sounds like it needs a new motor. Electric motors can develop bad spots on their coils. What happens is they begin to work intermittently or only when hit. This is the same problem with a cars starter motor. Probably a pretty easy fix, just unplug the power to the washer for safety and pull it out and get a part number off the motor assembly then order up a new motor. If you have a multimeter and are comfortable working around live AC voltage to can see if power is being sent to the motor at the power connector.
Jan 07, 2014 | GE Profile WPRE6100G Top Load Washer
GE top load profile washer won't spin. It starts
The tub hangs on 4 support rods. Lateral movement is kept in check with 4 bungy cords bolted to the top of the tub. If that washer is not level the tub will hang to one side and the fancy controls will declare an error. Make sure all your rods are good (they drag the base of the machine when worn out and make a heck of a racket) and the bungys are not stretched and the machine is level.
Aug 04, 2012 | Washing Machines
GE Washer WVSR1060BOWW
put a new coupler in it its between the motor and the transmission
Mar 18, 2008 | GE WBSR3140DW Top Load Washer
Spin cycle
its sounds to me that the bearings are going, it would show more in the fast spin Close Ireland bye bye
Nov 21, 2007 | Frigidaire GLTF1670A Front Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Doesn't spin
THE COUPLIN BETWEEN THE MOTOR AND THE TRANSMISSION IS BROKE!  IT'S EASY TO FIX.
Oct 11, 2007 | GE WHRE5260E Top Load Washer
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
GE Washer Spin Cycle Problem
gnarly, do you have the updated motor, harness and start cap? If it goes into spin and does this chunk a chunka chunka bit. Take a meter to the white and white/red wire going to the motor. If you have a steady 120V, replace the motor with the new kit. What the motor is doing is jogging between high to low speed. Catriver..post back.
Oct 17, 2006 | GE Profile WPSR3120WWW
GE WBSE2090A Top Load Washer Logo
141 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
