Question about RCA R52WM24 52" HDTV Projection Television
REPLACE SCREEN the screen has marker all over it and its permanit
  • 22 Answers
You can either try www.tritronicsinc.com or www.tvscreenprotectors.com for replacement screens
Posted on Jun 15, 2008
  • 4,234 Answers
There are 4 variants of your model listed. Can you please post the complete model number? There should be letters and numbers following the R52WM24. The front protective screen does not appear to be a separately available part. The screen assembly runs about $170. Post the exact model and I'll get you the order number and costs.
Dan
Posted on Jun 09, 2008
My daughters leapad screen is cracked and I seen your website and read good things so I was wondering what can you do for the cracked screen?
You can't replace the screen. Been there, done that. But, call the Leappad company and tell them what happened. They'll have you read off the serial number, and then will want you to take pictures of all the numbers and the damage, and email it to them. Then they'll email you back, asking you to write some letters and numbers across the screen with permanent black marker, and again take a picture and email. Then they'll send you a new one. I didn't have any warranty on mine. But call!! Seriously, they had a new one at my house in less than a week!
Oct 16, 2014 | Computers & Internet
Tip
Projection Screen Tip
When mounting a screen on or near a wall, consideration must be given to items such as marker boards, maps, and pictures that will be placed on the wall behind the screen. Be sure to leave enough clearance behind the screen surface to eliminate the possibility of damage.
on Aug 16, 2010 | Office Equipment & Supplies
My 3yr old daughter used permanent marker to write on our toshiba regza flat screen tv.. how do i remove the ink from the marker?
there is a liquid called stoko slig which is used to remove permanent marker they are on the web i think they based in stafford hopes this helps
Oct 18, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Calibration for 8060 touch panel
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
May 05, 2011 | Panasonic Workio DP-3530 Copier
Can not adjust the size of my screen. it pops up as OSD Lockout, and my installation CD will not play. can i get a download online?
Don't worry please just follow the easy steps and fix your problem<br /><br />Right click anywhere on your desktop.<br /> <div style="display: none;"> <li id="jsArticleStep1"></li> <li id="jsArticleStep2"> 2 Click "Properties."<br /> </li> <li id="jsArticleStep3"> 3 Click the "Settings" tab in the window that is now on screen.<br /> </li> <li id="jsArticleStep4"> 4 Click on the marker in the "Screen Resolution" portion of the window on screen. Slide it to the left to make your desktop resolution smaller. Slide it to the right to make your desktop resolution bigger.<br /> </li> <li id="jsArticleStep5"> 5 Click "Apply" to save your changes when you've settled on a desktop resolution with which you are comfortable.<br /> </li> <div style="border: medium none ; overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none;"><br />Read more: <a style="color: rgb(0, 51, 153);" href="http://www.ehow.com/how_5925464_adjust-size-lcd-desktop.html#ixzz0xoEQrNx5">How to Adjust the Size of an LCD Desktop | eHow.com</a> <a style="color: rgb(0, 51, 153);" href="http://www.ehow.com/how_5925464_adjust-size-lcd-desktop.html#ixzz0xoEQrNx5">http://www.ehow.com/how_5925464_adjust-size-lcd-desktop.html#ixzz0xoEQrNx5</a><br /></div></div><br />Click properties<br /><br />Click the "Settings" tab in the window that is now on screen.<br /><br />Click on the marker in the "Screen Resolution" portion of the window on screen. Slide it to the left to make your desktop resolution smaller. Slide it to the right to make your desktop resolution bigger.<br /><br />Click "Apply" to save your changes when you've settled on a desktop resolution with which you are comfortable.<br /><br />Thanks .<br />Have a great day.<br /><br />
Aug 26, 2010 | Computers & Internet
How do we remove erasable white board marker from the apollo screen?
With Windex, just use a wet rag afterward to make sure the ammonia is not left behind. If the screen is stained that is a different issue as you will have to use a cleaner that actually removes some of the screen, but doesn't eat through it entirely.
May 07, 2010 | ACCO Brands Apollo Projector Screen
Stains on the LCD monitor of Permanent marker
you could try mean green or totally awesome gotta love dollar tree. but be careful if you press too hard you could crack the screen or cause a pooling effect that may or may not go away. Oh or rubbing alc. last resort use liquid lighter fluid on a cloth.
May 22, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Permanent marker
use marker erase fluid or any quality cleaner product
just remember that it is a LCD screen so don't press hard when removing the mark
Nov 02, 2017 | Sony SDM M51D 15.1" LCD Monitor
Cleaning permanant marker from LDC screen
try and write over it with a dry erase marker. I know that if you write on a dry erase board with a permanent marker then completely cover it with dry erase marker then erase it it will remove it.
Nov 20, 2007 | Smart Modular SV3170A
Black marks on screen
This is normally a problem of panel.you need to replace the panel.
Samir
Mar 11, 2007 | LG Flatron L1710B 17" LCD Monitor
RCA R52WM24 52" HDTV Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
