Question about Maxtor Hard Drive
Can't detect hard disk
My system can't detect my maxtor 1gb hard disk. sound coming from the hard disk is really noticeable.
  • Arora Singh
    Arora Singh Jun 23, 2008
    how to construct a hard disk, after dismantaling
  • Anonymous Dec 01, 2008
    I could not make any of windows and linux platforms recognize
You throw it
Posted on Jun 18, 2008
My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Apr 20, 2010 | Maxtor Hard Drive
Can't open Maxtor one touch 4 mini
If the external hard disks is plugged to a USB port and is not detected anymore, try uninstalling the USB Root Hub devices in the device manager. They will automatically be reinstalled on reboot and that can help fix detection issues.
But did you look in the Disk Management module of Windows to see if the disk is there? Right-click My Computer and select Manage.
Jan 05, 2010 | Maxtor OneTouch II external hard drive...
My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
Just keep setting till you put at the right position where the system recognizes it.
There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
Take care.
Jan 04, 2010 | Maxtor Hard Drive
Computer is not detecting my maxtor onetouch III
the hard disk interface could be broken, open the hard disk case and use it as an internal hard disk as a slave in a computer to save your data
Oct 27, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
External Hardisk Maxtor 4 One Touch not detected
Have you tried different USB cables with the drive? If the drive is self powered (no ext power supply) which I think that one is, then it needs a really good cable to draw the 5 volts from the USB port. If you have tried a known working cable, then it could be the USB controller or the disk itself. You can buy the USB box on eBay really cheap and move the drive over.
Apr 13, 2009 | Computers & Internet
System not detecting my external hard disk
try going onto computer and see if it has removable disk right click and open or try putting usb in another port or if a disk came with it put that in .
Dec 28, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Maxtor III 600 gb will not mount
What Operating system are you using ?
I'll assume your using windows.
Try going to disk management
it may not have any partitions
you can get into the disk management by pressing start --> Control Panel ---> Administrative Tools --> Computer Management --> Disk Management.
Once your in Disk Management you should see the 600gb
After you find it right click and either format / import foreign disk
(This applies to internal hard drive only)
If Hard drive is not listed you may have to set jumpers correctly or check bios to make sure hard drive is detected
Feb 22, 2008 | Maxtor OneTouch II external hard drive...
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
I delete all the partitions from my hard disk. i didn't make partition.when i restart the system,msg came that nofixed drive present.bios don't dectect my hard disc.my hard disc is maxtor d540x-4k. how can...
Assuming this was your only hard disk, there is nothing on the disk for the BIOS to boot from. You need to boot from the installation disk for your operating system. The OS installer will then let you create a partition and install to it.
Mar 06, 2007 | Maxtor DiamondMax D540X 40 GB Hard Drive
Maxtor Hard Drive Logo
78 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
