Question about Electronics - Others
Flash drive i need to reformat a write portect tdk 1 gig flash driveand no longer have the software and have lost the codes to acess it wat can ui do
  • Anonymous Dec 26, 2008
    it doesnt work
  • 94 Answers
Select the drive and right click.
u will get the format option
Posted on Jun 12, 2008
I can't add files to my 16gb TDK gold flash usb drive. I can remove them. even when there are no files in the folders at all, the info tab says it has stuff on it. so i looked for a 'format' tab and...
Try RMPrepUSB - Quick Size Test (it will destroy all data but test the drive) or FakeFlashTest. If it tests OK, reformat using RMPrepUSB - Prepare Drive.
Oct 25, 2013 | TDK Electronics - Others
I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
Hi Kent:
F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance manager has already been replaced.
- If both are replaced the problem has been repaired.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | KitchenAid Washing Machines
How do i reformat my tdk usb flash drive
1. Open Windows Explorer.
2. Click on the icon for your USB drive.
3. Right-click and click "Properties."
4. Click "Format drive."
Regards,
D
Aug 27, 2011 | Computers & Internet
I formated my TDK USB-STICK 4GB TRANS-IT flash drive and now it is has only 239mb space, how can I recover the lost space.
Reformat with this utility.
http://www.pcworld.com/downloads/file/fid,64963-order,4-page,1/download.html
Mar 27, 2010 | TDK (CD-RW74HSFXS5) Storage Media
I have mistakenly formated my TDK 8GB TRANS-IT FLASHDRIVE and altough it is empty it looks only 9.95MB capacity. Any suggestion to solve this?
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it.
Try formatting using Disk manager.
Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Dec 19, 2009 | TDK (CD-RW74HSFXS5) Storage Media
TDK usb flash drive 8GB can not hold more than 5GB
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format Flash Drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 15, 2009 | TDK (MF2HD50PK) (50 Pack) (TDKMF2HD50PK)...
Tdk trans it 4GB secure area missing
hi sir
sir my flash automatic write protect . tdk 2 gb
Sep 19, 2008 | TDK (CD-RW74HSFXS5) Storage Media
Malfunctioning flash drive
I have special data recovery software just for this purpose. Send me an E-mail and I will send it to you as an attachment. Also send me you number and I will call you for free to teach you how to install the software and retrieve your files. I know where you are coming from I lost 2 gig sd full of mp'3 before I found this software. I wound up just reformatting it and it worked fine, but I lost all my stuff. I wish I had someone to teach me what I had to learn the hard way. Anyway, do NOT format the Flashdrive! I will get your stuff back for you.
George geokohler @gmail.com. Make sure you rate this one a Fixya for me Bro. Thanks
Jul 29, 2008 | Electronics - Others
Electronics - Others Logo
60 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
