Festures of vista as compared to xp
Give me some of the features to make presentation
  • 191 Answers
Put "WIN VISTA FEATURES"
IN www.google.com
it will search all available features along with the screenshots which will help you make a good presentation.
Posted on Jun 09, 2008
How do i fix "virtual router" software downloaded but does'nt work on my laptop.
Go to Control Panel, choose "programs and features" icon.
After it presents a list of programs, choose the virtual router and click on it. It should then give you the option to un-install it.
Mar 12, 2015 | Computers & Internet
Tip
How to test performance of Flash Drive
Check Flashis a freebie program that helps user to test and format flash drives with the utmost ease. It is designed for maintenance operations as well. The interface is a simple with a single window available, which provides all the test-related settings while presenting the drive map, log and verification progress. The application is capable of running both read and write tests in order to determine the speed performance of the device and its health.
cheeckflash
Check Flash presents the settings in the right part of the screen in four different sections covering Access type, Action type, Test length and Test results. Of course, there is a section that lets you choose the flash drive to be evaluated and which features a refresh button, thus allowing adding multiple removable drives without having to restart the program.
The way the read/write tests are performed and the list of options available for the operation are set according to the way you provide access to the flash drive. You can choose between using a temporary file, access it as a logical drive or as physical device. The differences between these three types of drive access consist in the safety level of the procedure and the number of options enabled.
Using a temporary file for the test gives you a minimum of features but, on the other hand, it is totally safe for the evaluated device. Treating the flash as a logical drive will give Flash Check access on partition level and is the second safest alternative to use; plus more options will become available under the “Action type” section.
The most unsafe method to test the removable storage device is to treat it as a physical device during the evaluation. This method is not recommended as it is unsafe for all the partitions present on the selected device but, on the other hand, you benefit from the full set of features in the software.
In “Action type” you get to choose between six procedures to test the removable device, all of which being available depending on the access type specified. The list of options includes read stability test (reads all data a few times and verifies the CRC given on first pass), low-level initialization (available only if you treat the flash as a physical device), which lets you edit the partition information of the selected device, save image (saves full binary image of the chosen partition or device), load image (writes a previously saved binary image) and full erase (effaces all of the drive’s surface).
For 50% of the presented actions several tests can be performed, continuously or until you decide to stop the assessment. All options in the “Test length” section are pretty clear, but “Burn it!” is the one that is not self-explanatory. It actually sets a loop in the testing that requires your intervention to stop.
In the lower part of the screen the test results are displayed: number of completed cycles, error found, read and write speed. Also, there is a progress bar to give you a hint on the completion of the operation. Unfortunately, the application cannot estimate the finish time. Left hand side of the application window shows the drive map, log and legend.
Check Flash 1.08 supplies a fat set of features to test your flash disk and see exactly how fast it can read and write data. It is portable and flexible enough to let you choose from three different drive access methods as well as select between six tests to be performed and how many times to repeat them. It is a very handy instrument that can help you detect the fake flash memory drives.
on Jul 15, 2010 | Computers & Internet
Tip
AOL Information AOL has a compression feature built into the browser that...
AOL Information
AOL has a compression feature built into the browser that compresses all the graphics you view on a web site. The following info will assist you in turning off this feature. Doing so will allow you to download graphics off of this site that are uncompressed. You will also find your viewing pleasure enhanced by the fact that you will hopefully be able to see the graphics as intended by the designer.
AOL's default in Internet Explorer for Web Graphics is "Compressed". That can be changed by going in "My AOL" and then Preferences. Go to WWW, which will bring up the Internet Explorer preferences. Click on the tab for "Web Graphics" and then click to remove the Check Mark on "Use Compressed Graphics"
It does help. You may also run Netscape Navigator while logged on to AOL and it gives a good presentation of web sites.
on Dec 26, 2009 | Computers & Internet
I want to advertise my business on youtube, how do I do it?
Hi Simon
If you want to endorse your product onto youtube you have to make a good video Presentation featuring your product then sign up or login on your gmail account then make your channel with custom url related to your product brand then send or publish your video with your contacts !!
Give feedback it you like!!
Oct 31, 2013 | Computers & Internet
I did not have it on my laptop and i cannot affort it sometime i want to type out something and i cannot do it.
Windows comes with two programs built in that let you type. Notepad is a very basic text editor without formatting. WordPad is a very basic word processing program with a few formatting features. Both of these might give you what you need if you just want something simple.
As an alternative to MS Office, you can download and install OpenOffice absolutely free. OpenOffice gives the features of Microsoft Office (word processing, database, spreadsheet, presentation and graphics), but doesn't cost anything. It can also read and edit MS docx format files, and can create pdf files. If you want to do some serious work but don't want to pay Microsoft, OO is what you need.
Aug 07, 2011 | Microsoft Office Professional 2007 Full...
It turns on and off but won't advance my PowerPoint presentation.
Did you pair it with your mac first and install the software?
Here is a link to the user manual that shows step by step instructions on how to set it up...
http://cdn.targus.com/web/us/downloads/amp11_ug.pdf
Here is a link to the software download if you want it (has a few more features than default). http://cdn.targus.com/web/us/downloads/targusdevicecontroller2.1.0f2.dmg
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Targus Bluetooth Presenter for Mac
Need updated map that will tell us the right lane to be in.
You cannot install features in your unit that it was not designed for. Updating the maps will NOT install Lane Assist or any other feature found in newer Garmin models.
Jun 22, 2010 | Garmin StreetPilot C330 GPS Receiver
Integrated WebCam
Hi there! Try downloading the Dell Dock from this website:
http://delldock.com/
It gives you cool features including webcam!!!
Hope it fixes it!!!
^_^
Jun 03, 2010 | Dell Latitude E6500 Laptop
When someone calls me and wants to leave a voicemail, the message asks to input my phone number, how do I get rid of that?
go to the common setting in ur calling option.then go to the SEND MY NO. & choose
set by network option.
i dont know about ur mobile features but in ur mob. if set by net... option is not present then choose ON option.
it defntly works my friend.
dont go on my ranking, its none of ur business.
i give the proper soln so give me proper feedback.
Jul 04, 2009 | Apple iPhone 3G
INNOVAGE digital keychain disc download problem
DOWNLOAD ''PHOTAGS''
USE WINDOWS MEDIA PLAYER FOR MP4 BY SYNC FEATURE
Dec 01, 2007 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
