Question about Indesit Washing Machines
MY KNOB KEEPS CLICKING ON A INDESIT WI141 WASHING MACINE
Clean out the filter which is under the kickplate on the bottom right of the machine. HOpefully this should fix it.
Posted on Sep 19, 2008
  • charles tindale Dec 12, 2011
    i have the same machine with the same problem ive cleaned the filter at the bottom still doing the same thing
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
W83t, programme selector knob keeps clicking over clockwise. is it just a faulty switch?
No it is not a faulty switch, it is the selector switch going round because of another fault on the washer, it is usually associated with a faulty control module.
Check your handbook and see if there nis a reset point on the selector switch dial, usually marked with one or more solid black dots.
Hope this helps.
Feb 02, 2010 | Indesit W 83
Please help me i lost my washing macine booklet and am unable to get a proper combination i have indesit washing machine wdl 106 i need a perfect combination about temp and all three knobs. cuz right now...
check the internet for a manual for your washer most of the time you can down load them. Put in the name and model number and state you are looking for manual.
Oct 31, 2009 | Indesit WA 125 Front Load Washer
No water coming into machine
you might have a clog, or maybe you didnt turn the water on. turn off the water and disconnect the hose get a bucket and turn the water on a little bit if watter comes out try inspecting the water hose in the washing machine and see if something is clogging it
May 08, 2009 | Indesit W 123 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
My frond loading Indesit washing machine won't drain.
your machine has a filter on the bottomn roght hand side looks like a black plastic knob..torn this anti clockwise watch out for water coming out of it have some towels ready clean it out and thaen out it back on turn clockwise and that should sort it out hope this helps
Sep 21, 2008 | Indesit W 123 Front Load Washer
Washing machine
did you reset the machine after you checked the filter? if not put the selector switch to any of the stop positions the switch on wait till the on/off light flashes rapidly , then switch off and try again.
Aug 16, 2008 | Indesit W 123 Front Load Washer
Hotpoint aquarius washing machine
hiya
i think this is down to a faulty pressure switch, could quite possibly be a faulty pcb, as hotpoint now use indesit components which are poorly made unfortunatly.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing macine indesit wil103
i need a intrution manual for my indesit wil103 washing machine
Jul 09, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
225 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
