VCRs
Problem for VCRs
Generic problem for all VCRs
Easy cap cannot install easycap driver in ...
By coozboy on Jun 09, 2008
Hey Guys
Well guys this is my system as you can see...
i bought the easy cap for $180 and b4 that i checked this site and see it works great but for meh it is'nt....
i cant install the driver the give meh this error
they said upgrade to SP2 but i have a better version.
so guys do u have any idea or any help???
plz reply ASAP
thanxx in advance.....
Comments:
Jun 11, 2008
- guys need help plz help
Same Problem
Apr 19, 2009
-   I have the same problem installing the device, if anyone knows how to fix this problem please email me, msc-jkl@streamyx.com, tqtqtq....... -   Guest
Apr 14, 2009
-   Where can i find the drivers for this device.. XP home Sp3 -   Guest
Nov 19, 2008
-   Same exact problem. It looks like there's a solution below, though.
-   Guest
Nov 13, 2008
-   same problem however:Magix send me a special driver for Windows XP SP3.0 which I cannot install because the ZIP is refused by windows.....
so where do I find a driver for my USB EasyCAP.......
-   axbx
Oct 27, 2008
-   yeah i do it said the some getting pissed off now-   Guest
Best Solution
posted on Sep 07, 2008
Helpful)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
I have XP with SP3 installed and I had the same message about updating to XP SP2 so the driver would not install from the DVD.
The solution seems to be to install all the software then insert the easycap in a USB port. Tell XP not to install the drivers automatically. Instead, before you start this entire operation, locate the drivers subdirectory on the DVD (mine were in drivers\BDA32) and tell XP to install them manually from that location. This seems to have worked perfectly - there are a number of drivers to install and once the video drivers are installed eventually the audio drivers then get installed automatically.
Solution #2
posted on Sep 20, 2008
Helpful)
duditz
Rank: Apprentice
Rating: 90%, 8 votes
sasas
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jun 14, 2008
Somewhat Helpful)
jerryg50
Rank: Wiz  Televisions & Videos  Expert
Rating: 84%, 940 votes
There is a problem with SP-3. There are many older softwares and drivers that don't recognize it as lagitimate. This is because in the software code of the softares, it is looking specificaly for SP-2, and not looking for "SP-2 or greater".
I noticed that there is an indication that you have only 512 mb RAM. With XP-Pro it is best to have 1 gb or greater. With SP-2 or SP-3, this becomes even more of an issue.
Jerry G.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jan 14, 2010
Very Helpful)
TeezyHD
Rank: Apprentice
Rating: 100%, 1 votes
Looking for the driver files for your EasyCap USB video capture?
This is a guarantee fix!! 1) Download vuze (vuze.com) or use any bit-torrent client application. 2) search for easycap on btjunkie.org and download the .iso or .rar file.
If you are unable to open the files, just google or download winrar or poweriso and you are good to go.
Was this helpful?
Yes
No
Solution #5
posted on May 03, 2009
Very Helpful)
fixyajoin
Rank: Apprentice
Rating: 100%, 4 votes
To install the driver on a system with XP SP3 (it may also work with Vista) just plug in your EasyCap USB device. When Windows asks for drivers, simply point to the folder on the CD that says "Drivers" then to 'BDA32' or 'BDA64' (depending on your system type - 32 or 64-bit). Windows will install your EasyCap device and you can start capturing video (if a warning message pops up just hit 'continue anyway'). Thats all.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #6
posted on Aug 10, 2009
Helpful)
seamon53
Rank: Apprentice
Rating: 83%, 3 votes
August 11, 2009 -
The driver for "KWorld DVD Maker USB2.0 1.1.0812.1" is compatible with "EasyCap USB 2.0 Video Grabber" under XP SP3, and I've put it up on my website so it won't disappear. Get it here:
http://www.pixelparadox.com/temp/v1.1.0812.1_060320.zip
Plug in your EasyCap USB to a USB slot, and don't forget the RCA jack plugs into the a line-in to capture your sound.
Unzip the zip file and run SetupDrv.exe.
EasyCap will be recognized as a "USB 2860 Device".
I've done captures from VHS tape to WMV video with "Windows Movie Maker" and "ULead Studio SE" with excellent results under XP SP3.
While you're there pick up a great game or screensaver from
Cheers,
Ken Seamon
Was this helpful?
Yes
No
Solution #7
posted on Sep 12, 2008
Somewhat Helpful)
antoniocason
Rank: Apprentice
Rating: 75%, 2 votes
driver
Was this helpful?
Yes
No
Solution #8
posted on Jul 16, 2008
Somewhat Helpful)
asasas696
Rank: Apprentice
Rating: 75%, 4 votes
Just search for the oem.inf file (or similar) in the Drivers folder of the CD. Right click it and select "Install"
Was this helpful?
Yes
No
Solution #9
posted on Nov 06, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Service Pack 3 dosn`t work good with dis driver, the PC is very, very slowly.
MfG
Solution #10
posted on Jul 04, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
what i did to fix the problem is uninstall the windows sp3 update instal the usb video grabber then reinstall windows sp3 update. thats the only work around i know of.
You can use windows update and use there drivers yet the drivers make streeches and cuts some of the video from the oringal sorce so stick the orginal drivers. not the windows one.
Popular Solutions for VCRs
Questions and Unsolved Problems for VCRs
Answer
which is better sylvania 6260VE vs funai picachu vcr recorder
Answer
Old Magnavox VCR will not accept most tapes (will accept a tape or two - but not any new ones... (More)
Answer
can not find my instructions book to turn my freeview tv into my video recorder
Answer
Panasonic AG-DV2500 DV/Mini DV VCR http://i779.photobucket.com/albums/yy79/semipage/AG_DV2500.jpg it... (More)
Answer
my logik tv displays a blue screen with no picture and sound
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 18, 2008
I can't install the driver on a XP Sp3 system
Comment by Guest, posted on Sep 10, 2008
I have Windows XP Professional Service Pack 3. The installation of the EASYCAP VIDEO DRIVER always prompts me to upgrade to SP2. I however have a better Service Pack 3. How can I solve the problem.
Describe your VCRs problem:
Select a Category:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top VCR Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
VIDEOGAME REPAIR SERVICE
(845) 592-2026
At Elite Audio Repair & Restoration it is our...
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
