Question about Archos 404 Digital Media Player
How Do I Go About Replacing The Battery Of My Archos 404 In The UK?
I have recently discovered that overlong charging periods for my Archos 404 has fried the battery, and the device does not operate at all.
I have also seen on the Net that replacement batteries ARE available, but I don't know how to go about replacing one.
Is there anywhere in the UK that can do this?
Hi! You should try this link: http://forum.archosfans.com/viewtopic.php?t=3906
Posted on Aug 29, 2008
  • 3 Answers
Will no longer take a charge..is there a battery that can be purchased and how do I get one
You can get a battery off of ebay. Just search "archos 404 battery". Just search on google how to install the battery.
Jan 01, 2010 | Archos 404 Digital Media Player
My archos 404 isn't charging o coming on at all
Either the battery pack is dead, or the ribbon cable connection between battery pack and main control board is faulty or loose.
Nov 09, 2009 | Archos 404 Digital Media Player
Archos not charging
You don't say how old the device/battery is. Does it fail right out of the box new? This behavior can be common with an older failing battery. If this occurs in a new device then it is faulty and needs be sent back on warranty.
Aug 18, 2009 | Archos 404 Digital Media Player
Archos 404 camcorder
sound like you may need a new battery. look on the archos FAQ page to see if that is what it is. if so you can do this two ways you can fit the battery your self, you can buy the battery from newmp3technology.com or type archos.co.uk. or you can send it to the archos repair by calling 0870 609 1693 this will put you to the archos uk repair team
Jun 18, 2008 | Archos 404 Digital Media Player
Archos 404
Your battery may be dead. This happens sometimes when the charge is allowed to completely drain. The dialectric (or something) in the battery doesn't work when there is no charge at all in it.
You may need to change the battery. Check to see if the case appears to be loose at the edges (or there is a gap). This may mean that the battery has swollen and you should therefore change it.
http://newmp3technology.com/404-battery.htm
Jun 07, 2008 | Archos 404 Digital Media Player
Battery problem
I had the same problem and changed the battery on Monday. Works fine. There are just four small screws to remove.
Replacement battery can be found here:
http://newmp3technology.com/404-battery.htm. I used them and can confirm that the battery comes with the right connector for the Archos 404.
Took 10 minutes to replace it.
Good luck.
Jun 02, 2008 | Archos 404 Digital Media Player
Archos 404 does not work at all since using Archos Docking Adaptor
You should try to only chare your Archos only when it is completely dead and charge it fully then the battery will be regular
May 02, 2008 | Archos 404 Digital Media Player
Archos 404 not charging
Dont use the USB to charge the 404. Use a wall charger that accepts USB. Wally world (Walmart) has one for 15 dollars that has 2 USB ports. It works for me. Also the docking station will charge the 404 in no time at all. It's 80 dollars. Make sure you get the generation 4 unit
Apr 25, 2008 | Archos 404 Digital Media Player
Battery problem
I might have got this wrong but i thought there a fix you could download from the Archos site,i had the same problem with my mate's one only got to watch 1 and a half episode of the tv series of Heroes,i also ordered a battery type charger that could give it up to 2-3 charges while you travel.
Dec 03, 2007 | Archos 604 WiFi Digital Media Player
Archos 404 Digital Media Player Logo
1,013 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
