Question about GE GSS25JEMWW Side by Side
GE ice maker problems
I have a GE side by side refridge. I had a service tech. come and fix the ice maker because there was a lawsuit etc. with the icemaker system. The motor has been replaced and I think he replaced a circuit board. It still does not work. It doesn't make any noize when the lever is pressed and there is no sign of any ice in the tray. Any thoughts here?
Thanks,
Kevin
  • 1 more comment
  • FLYIN250 Jun 09, 2008
    The door is closed when I am trying to cycle it. The only thing that works is getting water. Just won't make any ice and the despencer does not make the turning noize like it is going to dispence.
  • thekeeper23 Sep 25, 2008
    Just had the water lines hooked up. Fridge was here when I moved in but was not used. It is a model Gss22wgmc. The water will disperse but no ice. The light is on on the ice maker but nothing happens. In fact, the fridge side of the refridg is really cold. I have lowered it to a number 3 cuz my salad dressing froze. Help.
  • 770 Answers
To cycly that im you need to have the door switch closed as well have you held that while trying to cycle it?
Posted on Jun 09, 2008
  • 1 more comment
  • Gary Davd
    Gary Davd Jun 09, 2008
    what is your email i will send you the service manual for the unit as there are several steps you need to do to
  • Gary Davd
    Check your email
  • Gary Davd
    Gary Davd Aug 04, 2008
    please rate this call Thx
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working now refridge seals are hot, but still cooi
okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Dec 29, 2008 | Refrigerators
Ge artica side-by- side ice maker fillsup once then stops making ice? whats up?
YOU NEED TO HAVE YOUR ICE MAKER CHECKED AND SERVICED BY A TECH.THE TIMER MOTOR INSIDE THE ICE MAKER COULD BE STICKING.
GOODLUCK.
MOHAMED
Sep 19, 2008 | GE Refrigerators
Ice maker
peace,
It's hands on service time.
Ice makers in a side by side are not easy for even the tech to diagnosis!
Leave this headache to the hands on tech!
You will be much happier this way! And relaxed.
bless you,
ngafm
Please give me a good rating for this valuable advice!
Jul 16, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice maker not making ice
The fill tube could be frozen. Gently use a hairdryer. If not you have to check the fill valve coil in the back to see if it's getting power. If it is replace the valve. if not check wiring connections etc. If there's no power out of the Im to the valve, replace the IM
Problems with water are most common tho. Please rate this
Jan 23, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
615 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
