Question about Refrigerators
Our 4 yr old refridgerator & freezer quit working. power was on because the temp indicators showed 48 & 28 degrees. Should be 36 and 1 degree. We moved all of the food out and obviously temps were much higher after having doors open for a long time. Fridge was no running or cooling. Then later that night, after about 8 hrs, I checked and temps were back to where they should be, 35 and -1. Any clue as to why this happened?
  • 828 Answers
These unit normally, if frost free model has a defrost cycle. It is possible that at the time you noticed it the system was in its defrost mode.
Posted on Jun 10, 2008
Proper temp for refridgerator
36-40 degrees F.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator and freezer are not getting cold but I can hear the motor running.
Hello there:
If the compressor is running and you can hear it than you are going to have the refrigerant recharged in the unit.
If you continue to run the unit without refrigerant you will end up with the compressor quitting and this you do not want ok?
I hope this has been very helpful for you ok?
best regards michael
Nov 05, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE side x side refridgerator temperature is
unlikely both temp.sensors will be faulty at the same time. Notice how different the internal temps.are compared to the acurate one you are measuring it against. Almost certain board is defective because incorrect info in the processor will tell the compressor/s to switch off before time.(hence not correct temp. all the time.) Suggest replacement.I normally replace probes as well to eliminate problems later..
Sep 17, 2009 | Refrigerators
Our Kenmore is a side by side with ice maker. It's about 6 years old. The ice maker quit making ice about a year ago. We didn't get it fixed. Now our refridgerator section won't cool. The freezer works...
Find the vent in the refrig that gets the air blown in from the freezer. When the unit is running you should feel air coming out of it. If not then you have a problem with the damper door. you can manually open the damper door but you might have to adjust it so it does'nt send in too much freezer air and freeze stuff.
Sep 08, 2009 | Refrigerators
Frosting up of freezer fan/fan runs continuously
Clean and check the seals around the doors, the unit is trying to compensate for temperature loss.
Jul 27, 2009 | Refrigerators
I have a ten year old Sub-Zero 650. The "vacuum condenser" has been displayed for over a year even though the coils have been vacuumed and are kept clean. The fridge has been working fine despite the...
Look on your sub zero for more model numbers. I have found some information indicating that the refrigerator thermostat may be the problem but need those numbers to confirm. Thanks, Sea Breeze
You can also find a user manual at this link
Apr 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
