Question about LG WM-2277HW Front Load Washer
LG intello WM12235
My washer is dislaying code SE what does this inicate,?
  • 2 more comments
  • maloula Jun 15, 2008
    hi sgt 48, the code could be 5E and the washer bleeps for about 10 seconds after trying to start the wash cycle, kind regards maloula
    hi sgt48 could it be a fault with the washer motor brushers, and if so can they be fitted with ease,
  • eric bosman
    eric bosman May 11, 2010
    Please check the machine model because Lg doe not recognize this code
  • Andrew Lauder May 11, 2010
    double check the code as I have never seen a SE error code, doesn't mean there isn't one though.
    Sgt 48
  • 489 Answers
SE error code means a communication problem between the display controls and the main control board.  You will need a qualified LG technician to locate and repair the problem.
Posted on Jun 26, 2008
My LG intello won't switch on can you help
There can be so many things causing issues with a washing machine, if you haven't already, getting a certified appliance repair person to drop by is the safest. If you had an error code, flashing lights, or something I could work with, that'd be a different story.
Jun 02, 2014 | LG WM1814CW Front Load Washer
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
I have a 2 year old l.g.intello apartment size washer numberwft8501tp it is touch control and i have no idea how to start it please help
I suggest you go on-line and type into your search engine 'lg intello washing machine manual'. You should be presented with a number of sources from which you can either download for free or have to pay. At some point they will ask for your particular model- wft8501TP- obviously!
Good luck,
John C
Feb 10, 2011 | LG Washing Machines
My washing machine, which is a LG Intello Washer WM1485FHD is display a code of OE. Could you please advise
That is actually a DE (drain error). Clean out the filter, located behind the access door on the bottom left side on front of the machine. If there was nothing in the filter, replace the pump motor.
Jan 31, 2011 | LG Washing Machines
Code error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 13, 2009 | LG WM-2077C Front Load Washer
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG intello washer WM1285FHD The code CL is on display how do i clear and get machine to work?
CL == Child Lock.
Press "Wash" & "Rinse" buttons simultaneously to set / clear.
Dec 26, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
393 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
