Question about Hoover Washing Machines
I have an old Hoover washing machine (maybe 5 years old) in storage and I have to use it because my current one is not working. When I plug it on and turn the nob to wash, nothing happen. I have checked the tap which is in correct position. The machine produces some sort of humming noise but no water coming out and no action at all. Please advise me. My email address is
Many thanks.
I have found a solution in a UK website. Machine fixed.
Posted on Jun 11, 2008
Why won't my machine stop filling?
replace water level sensor
if less than 5 years old
should be able to get the part from a washing machine repairer
or hoover washing machine parts supplier
Apr 16, 2017 | Hoover Washing Machines
My hoover will not fill with water when the start button is pushed and three lights come on H G D and all three flash all the time .Can you help
It could be that the water pump is jammed with a coin or maybe a kirby grip or something of that nature , pull your machine out and switch off the power , then tilt the machine up at the rear and check to see if the pump is turning by hand , if it is not turning properly it could be hat coin or some other object is jammed in it , you will need to take the rear cover off the pump and check to see if there is anything in it , if you find anything in it this will probably be the problem , put the pump back together and try the machine to see if it fills , good luck , also if your machine is under 5 years old Hoover will replace any parts as you have a 5 year guarantee on parts
Aug 22, 2014 | Hoover Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ... > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover Nextra No Lights Not working
please check the fuse in the plug it should be13 amp it has no doubt blown after replacing it and happens again there might be a problem with the heating element it might be faulty or ruptured due to short circuit in the element eric
Dec 25, 2017 | Hoover AAA160 Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Very noisy Hoover VHD9143ZD washing machine - just 2 years old
yes bearing housing get loose in plastic drum. needs drum replacement.
Oct 29, 2009 | Candy Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Programme Lock
did you try to hold the button in for 5 to 10 seconds let me know if this worked?
Sep 27, 2007 | Hoover AAA140 Front Load Washer
Washing Machines Logo
93 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
