Question about RCA P60921 60" Rear Projection Television
Chassis no PTK195MT
RCA P60921 60 in. Rear Projection, Chassis no PTK195MT Won't turn on, I was watching TV and I went to answer the door, talked to the person a couple mins. came back and there was a burning smell. I took the back panel off and what I can tell I have a burnt area on PART # T14401 IHVT. The two wire leading to this part was black coated like it was burnt. So I feel this is the part that went bad. My question is Do I need to replace the whole Main Chassis Board or can I replace just this part and how?
Thanks for your help.
  • Anonymous Jan 29, 2009
    what is considered a reasonable price for a tech to repair this
  • 4,234 Answers
This part is called the flyback transformer and is part # 239111 at a cost of $68.99 from tritronicsinc.com. You can replace the transformer. It sounds like it developed a short internally. There may be other parts that were effected as well. If you are not comfortable working inside hte set, expect a service call to run about $100 for parts plus hte local labor rate.
Dan
Posted on Jun 09, 2008
RCA Projection TV Model P60925BL. Has sound but lamps don't turn. Chassis model PTK195LC
i went into setup option and the dvd player disconnected and I can't figure out how to get it working on the tv again. dvd is connected to video 1 on the dvd player and channel 3 on the tv ????
Dec 11, 2009 | RCA P60921 60" Rear Projection Television
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
I have a rca tv model d52w17 chassis # D416c30WC.
sounds like the flyback if your talking about the lower left when looking at the rear of the set.
Apr 12, 2009 | RCA HD52W59 HDTV Projection Television
Chassis no PTK195MT
I couldn't understand why you closed chat session as I said Hello and got no response.
Your tv requires RCA Part Number: 242676 Board and its available in Parts Store.
Need further help, let me know please.
Sep 12, 2008 | RCA P60921 60" Rear Projection Television
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
Unknown AutoLock on my Philips rear projection tv
If you look on the rear of the set and locate the chassis number can probably assist you. But I will need the chassis number for RCA & Phillips/magnavox.
Feb 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
60in. rca rear projection tv
1) Reset will not help
2) Older RCA projection tv's usually produce a good pix,
so you could fix it....
3) light box chassis pulls out to go to shop for repair...
4) For more info = provide service # and chassis # off back..
Please rate this solution...............
Nov 13, 2007 | RCA P46924 46" Rear Projection Television
RCA P52920BL
i'd like to help.that model# looks familiar.but that chassis num you gave looks more like a serial num all my rca prints go buy chassis # is there anothe num like ctc197 exet or ptk19 doc
Aug 25, 2007 | RCA P52921 52" Rear Projection Television
RCA rear projection tv
Dir TV projection Techcions, I own RCA Model:P52937 Chassis No.PTK195M26B. After a big flood here in Chicago, my basement got flooded and my projection TV was in water up to 1 foot. Befor I turned it on, I dreid it out perfectly, then, I turned it on, and a couple components from the power supply got burned up to the point where I am not able to read the part numbers that are on it. I was wondering if you have this kind of chassis and model service manual for this projection TV, or conponet part number i location 101 on mother boatd power supply. Thank you in advance, Darius If you prefeer, you may call my cell phone: 773-875-3926
Aug 02, 2007 | RCA P52937 52" Rear Projection Television
RCA P60921 60" Rear Projection Television Logo
225 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
