Question about Nokia N95 Cellular Phone
When i try to receive files through bluetooth the phone is saying disc full. the memory on the pone is empty. why is it sayin this and how can i fix it?
Nokia n95
  • barnesy84 Jun 09, 2008
    when i try to send a text message there is no dictionary on the phone it has something called smart text but i cant input my own words
  • 107 Answers
Try a hard reset on the phone or try updating software tips and tricks below
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI Number).
#pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
Posted on Jun 11, 2008
When someone send files thru bluetooth successfully,the received files it says empty ..plz help
Here let me give you a hint.First try to make back up all the important files which is stored in your phone memory and restore it by using *#7780#.However,if the problem still persist format it by using the code *#7370#.Thats you need to do it by yourself and I can guarantee you that it will surely works.Good luck
Feb 07, 2012 | Nokia C3 Cell Phone
Tip
How to receive large files through bluetooth in nokia 5800
You can receive large files in your phone if you have enough memmory on your memory card.If we receive a file through bluetooth , it will be stored in the message inbox.So if we try to receive a large file,the phone says not enough memory to receive.You can avoid this problem by changing the storage memory for messages.Before receiving large files through bluetooth,go to messaging.Then select options.Select the settings.Then select other.There you can see an option for memory in use.Select it and change the memory in use into memory card and press ok.Then receive the file through bluetooth.After saving the file,you can change the memory in use into phone memory.Thanks.
on Jan 08, 2011 | Cell Phones
My phone nokia N70 will register "memory is full, delete some items" whenever I access the message folder even if the folder is now empty.
The problem is that your inbox might have become full due to messages and received files via bluetooth..
try deleting some received files or clear all messages inside your inbox to free up memory on your phone..
Oct 13, 2010 | Nokia N70 Cellular Phone
Text memory full states on notification cant receive texts but i have no messages saved so i st .arted clearing out stuff tha had a storage i still have full memory. HELP PLEASE
Dear Sir\Madam,
I had a similar problem, and I was able to solve the problem by simply following the below steps. 1. If probably your phone has a bluetooth device and you have been receiving gallery files(i.e. Photos, Musics or Videos) via bluetooth, note that this files are stored too on your phone memory not the memory cards and this may consume space on the phone memory. So, try and move those files that you received via bluetooth in your received folder on your phone memory to the location of your memory card. This may probably free the space on your phone. 2. if you have been receiving bluetooth files as a message into your phone depending on the type of phone you are using, simply save them into your memory card by selecting the memory card path and delete them after saving so as to free space on the phone memory. Then try to delete as well some unwanted or junk messages from your phone in have more space on your phone memory.
Hope the information actually help. Regards
Sep 03, 2010 | Cell Phones
Hello I am having samsung GT-E1410 mobile. I am
SOLUTION TO RECEIVING FILES ON YOUR MEMORY CARD.
You cannot receive files on your memory card directly.
You are to receive it on your phones memory, then you move it to you memory card.
You ensure your phones memory is totally empty so you can receive your incoming files.
SOLUTION TO SEEING YOUR MAIL SENT
Go to messages,
select the message settings,
select the message sending option,
Select save and send.
once this is done, you will be able to view your sent mails in your outbox.
Take care
Jun 20, 2010 | Cell Phones
I can't save files or data directly to memory card
Samsung s3310 cannot import files to memory card directly,When we are transferring through Bluetooth.When we are transferring files through Bluetooth,it stores in default to phone memory and this memory cannot be changed to memory card memory.
There is one way to transfer large files with 500megabytes size through compression of file and splitting up to many sizes.We can use any software for compression and splitting up."ERROR MESSAGE:memory is full" can be avoided through this above way.
May 12, 2010 | Samsung Star GT-S5233 Cell Phone
My Nokia N73 phone keeps saying 'memory full delete data' when i try to send txt - but there is no data to delete, txts , images etc are empty. And memory details say there's plenty of memory. What's...
when it says memory full then see that all messages received via bluetooth are cleared from memory.And find out and deleate any unwanted applications in your phone memory.And if this dosenot solves your probs then switch off your phone and turn on at least after 5 minutes.
Jun 13, 2009 | Nokia N73 Cellular Phone
Bluetooth problem.
Your phone probably has a lock on it which prevents you from receiving ringtones, games, music, stuff like that from other users
Mar 19, 2009 | Sony Ericsson W910i Cellular Phone
Bluetooth and memory
try to restore your phone settings
Feb 06, 2008 | LG Prada KE850 Cellular Phone
Bluetooth
Files have to be sent one at a time to your phone and then each one moved to your phone's external memory, before sending another.  Unfortunately, there is no setting to send straight to your phone's external memory directly.  Please see my 'hints and tips' postings regarding jpg sizing and other media file information. Best of luck. El
Jan 19, 2008 | LG Prada KE850 Cellular Phone
Nokia N95 Cellular Phone Logo
114 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
