Question about Refrigerators
FRIGIDAIRE RLE1405 can you help we have had this FRIGIDAIRE RLE1405 for 2 years and its now not getting cold at all the motor is running all the time, it is noisyer than before.
3 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: Fan running but neither refrig or freezer is getting cold.
Your refrigerator may be stuck in defrost cycle. I know it has a defrost timer part number 215846602 Most times they are located inside the fresh food compartment behind the control panel. Sometimes below fridge and behind kick plate. The thermostat could be defective also. You can check that by unplugging the refrigerator remove cover and checking continuity between the two male connections located on the rear side of thermostat control turned as cold as you can turn it. Or you can join the two wires together and plug refrigerator back in to see if compressor comes on. When you find the defrost time turn clockwise slowly until the refrigerator starts. If these don't work let me know and we will do some more test. Sea Breeze
Posted on Jun 20, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: Frigidaire Fridge is not very cold in side
Try replacing the breaker switcth/capacitor assembly. Is right on the compressor.
Posted on Jun 28, 2009
How can I get my Frigidaire Dishwasher 900 series to start?
Sounds like you have a bad door switch. You might also have a motor that tends to freeze or lock up. It could possibly be a bad motor capacitor too. Does this help?
Mar 18, 2015 | Frigidaire Gallery Dishwashers
I have a Frigidaire model# FRS26H7CSB1. THE FREEZER IS NOT GETTING COLD ENOUGH AND THE FRIG IS COLD BUT ONLY WHEN SET TO LOWEST TEMP SETTING. The metal frame/pillar between the freezer and frig is very...
The freezer not getting cold enough is defiantly due to the condenser fan motor not working. You would be best served to replace the fan motor with the correct part number though others will work, a small desk fan blowing in the back would work. As to the temperature issue in the refrigerator, you might have a bad t-stat.
Mar 12, 2013 | Frigidaire Refrigerators
Hi, I have a frigadaire rle1405 larder fridge that does not get cold,could you please tell me where the defrost timer is on this model. Thank you.
Many of the frigidaire units had problems with the defrost termination thermostat located in the freezer compartment. (I have repaired many). It is around 12 dollars
It is clipped to a tube located in behind the freezer back panel. take out the
plastic vent and motor, unplug the motor (very carefully to prevent pulling out the
leads) the defrost termination thermostat has two leads and is clipped onto a
tube. The replacement will have heat shrink and wire nuts, but I often use
**** splices under heat shrink tubing to ensure no moisture gets into the connections and a dab of silicone at the ends of the heat shrink. Make sure the "colder" knob
is set in the middle on the vent stack as this will cause problems if set to "colder".
I have only seen one defective defrost timer (incorrectly assembled) which caused the
gear to stick in one position. You can manually rotate the timer to check operation with
a screwdriver in the access hole on the bottom of the temp control panel. (oddly the new timers are of a different make if it has failed). Unplug unit before servicing.
May 29, 2011 | Frigidaire Refrigerators
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
After emptying the ice bin on 2 year old side frigidaire, the freezer is OK, but the fresh food side has stopped cooling. Any ideas?
check that the fan in the freezer is running,it circulates the cold air,if it isclose freezer door,open refrig. door lookto the upper left you will see where the cold air enters the refrig compartment and should fill air coming thruough vent this is a motorized unit and they sometimes fail,also check the return air hole located at bottomof refrig.sometimes get blocked by plastic bags etc
Jan 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dual fan is not blowing as cold in the bottom and runs all time
Cannot handle grease, especially in that cold area. Super light weight oil only. Sewing machine oil or equivalent.
The rule in this business has always been. Oil is for preventative maintenance, not repair. If you were having issues with the motor, a new one is the correct proceedure.
Oct 22, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator does not get cold, motor is running, repairman says get a new one. only 1yr old (frigidair side by side)repairman said sealed system needs to be replaced.
Well, that's great for you since the sealed system is cover with a five year parts and labor warranty. Call a local Frigidaire certified repairman and tell him the situation.
Aug 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Jun 28, 2009 | Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
Dec 22, 2008 | Frigidaire FRT18FS6C Top Freezer...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
