My Nokia 1200 had a bit of water (not much, though) poured on it yesterday, and worked fine. However, its battery was low so it later turned off. When I got home and plugged in the charger, nothing happened at first. Several times a screen saying "Test Mode" appeared, but now my phone's all but dead. I can't even figure out how to open the casing to see if the circuit board needs cleaning.
-   the phone fell inside water when i dryed and switched it on it showed me contact service
-   philipbwala
Dec 14, 2008
-   I have the same problem. I wonder if I fried it by leaving the battery in too long. I have heard that water and batteries don't mix and will short out the phone. -   nikihiggs
Dec 13, 2008
-   ugh i have the same issue. does this mean my battery is broken?
-   gretchenmart
Nov 22, 2008
-   i have got the TEST MODE screen as soon as i switch on the phone-   Guest
i'm having the same problem as i type... a quick survey of forums showed that it happens most often with battery (hardware) compared to s/w problems. next time ur fone meets water(loo) remove the batteries immediately and the screen guard asap, too. allow them to dry for some hours and u should be fine
I have the LG enV 2, the connection from the charger to the phone has broken. Is there a battery...
(More)
I have the LG enV 2, the connection from the charger to the phone has broken. Is there a battery only way to charge it? the battery is fine, it's just the phone and I'm too close to getting a new one to pay full price now.
My 8 months old baby normally puts the port-end of my NOKIA 1200 phone into her mouth. Moisture from her mouth must have entered into the device. I opened it, removed the battery and dried it in the sun. It worked fine for some days and has since been showing me "TEST MODE" anytime I try to turn it on. Please help me !
recently spilit a glass of water, dryed it off work well for 2 - 3 hours ,started to maulfaction ,opened the case took out the batter still had water in it.put it in the hot water couboard worked sweet then droped on the floor only got the test mode screen.
