Question about Asko W6021 Front Load Washer
ASKO w6011 FRONT LOADER
Hi my 6 year old washer will fill with water and wash but will not drain or spin. When I stop the machine and reset it on the drain or spin cycle all it does is wash. It doesnt seem to register that I have changed the cycle. Can you help????
  • 2 more comments
  • Reebee Aug 03, 2008
    Thanx for that, it worked!!. There was a bracelet in there of my daughters which was stuffing it up.
  • sailca Aug 17, 2008
    Our W6021 did not go on the drain/spin cycle so I manually drained it and cleaned out the trap (coins and stuff). It still refused to drain and when on the wash cycle I hear something from the pump (catch basin area) which sounds like very small gravel or rock grinding around in there. Please help, we live in the country and it is difficult to get this thing serviced.
    thanks
    Dan Parksville, BC
  • David
    David Nov 19, 2013
    David
  • Anonymous Mar 13, 2014
    I have a Simpsons 9.5 kg top loader washing machine , its about 6 years old now, the problem was the machine is not washing and spinning ,just fill water and draining out, Please kindly identify the problem
For Sailca's problem, some of the stuff from the trap may have gotten into the drain hose and still be rattling. One time I used a shopvac (wet/dry) to clear the hose.
WHen you have the trap open, try spinning the pump impeller (plastic finned thing). It should have a bit of resistance from the magnets, but not anything grating.
Posted on Aug 21, 2008
    Problem Solver:
  • 5 Answers
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Posted on Aug 03, 2008
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Apr 21, 2011 | Roper Washing Machines
Asko front loader, fill with water but won't wash, drains water OK
Hi, Have you removed the back panel to insure the belt is on ? What about the spin cycle, will it spin ? (That will also tell you the belt is good by the way) I'll watch for your reply. Regards, Macmarkus :)
Dec 09, 2010 | Asko W600
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Asko W6761 - seems fine, starts to fill 40 seconds then stops!
Hello, my W6761 becomes the same. When it happens, you can clear the problem by "soft ware reset". Following is the procedure:
1. Power it on
2. Push Start/Stop buttom 5 times
3. Push "Enter", ">", "<", "Menu" buttons (from right to left)
4. Again, push "Enter", ">", "<", "Menu" buttons
5. Wait for 30 seconds that the above soft ware cycle resets the internal status
6. Power it off and on, again
7. You need to execute above "soft ware reset" within 15 seconds
Start washing and check to see if above reset the problem.
If it does not begin to work, repeat above "soft ware reset" cycle until it begins to work.
My W6761 once needed to repeat above cycle 7 times to solve the problem.
This problem happens in mostly in warmer season, so this will be related with high ambient or water temperature.
ASKO technician may replace the controller but even with the replaced controller, this problem often happens.
Tsunett
Mar 16, 2009 | Asko W6761 Front Load Washer
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
719 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
