Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2005 883 Harley Codes
My brake light stays on all the time and my lights flash 6 times when I turn the key on?
  • none113 Jun 12, 2008
    It was a blown fuse that caused all this!
  • 48 Answers
Check out the codes here
http://www.harleyhog.co.uk/0405troublecodes.htm
Posted on Sep 28, 2009
While riding the key light or alarm light stays on 2010 FLHTC
Hi, David you may need an alarm reset for more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Security light stays on mean Harley Davidson Forums
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief $6
Mar 09, 2016 | 2010 Harley Davidson FLHTC Electra Glide...
2003 harley Davidson softail check engine light comeson rpm goes up then everythinggoes backlike it never happened
See what error codes are stored:
Remove the protective plug from the data link connector.
Connect your jumper wire to the first and second terminal on the data link connector.
Turn the ignition switch on and wait for 10 seconds. The light will turn on for 4 seconds, then off for 6 seconds. After this 6 second interval, any stored trouble codes will appear as sequential flashes.
Count the number of times the lamp flashes; this is the first code. The code will repeat three times before playing the next code, if any, after a 3 second pause.
Record the codes and repost them..
Turn off the ignition switch and remove the jumper wire.
Aug 13, 2014 | Motorcycles
Ignition switch on, signals will 6 flash times, no brake light and bike is in shut down mode
Hi Lana, try: http://www.harley-davidsonforums.com/forums/electrical/32977-finding-resetting-security-codes.html Good luck
Apr 14, 2014 | 1993 Harley Davidson XLH Sportster 883...
Left rear blinker stays lighted all the time and acts like a brake light when brakes are applided and left front blinker wont flash on a 2000 dyna fxdl
Hi Anonymous, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all connector pins are corroded, broken, or loose. For a free wiring diagram please visit the website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Feb 05, 2014 | Harley Davidson Motorcycles
I have a 2000 dyna fxdl and the rear blinker is lighted all the time and dose not flash and when u hit brake light it acts like a brake light and the left front blinker wont flash
Good luck
Feb 05, 2014 | 2000 Harley Davidson FXDL Dyna Low Rider
How do I retrieve trouble code on a 2002 Harley ultraclassic
  • Remove the right side cover to access the data link connector.
  • Remove the protective plug from the data link connector.
  • Connect a jumper wire to the first and second terminal on the data link connector.
  • Count the number of times the lamp flashes; this is the first code. The code will repeat three times before playing the next code, if any, after a 3 second pause.
  • Record the codes and refer to your service manual for possible faults or conditions.
  • Turn off the ignition switch and remove the jumper wire.
  • Replace the right side cover.
  • Read more: http://www.ehow.com/how_5556684_pull-engine-codes-harley-davidson.html#ixzz2g8gNkq5I
    Sep 27, 2013 | 2002 Harley Davidson FLHTCUI Electra Glide...
    What troubleshooting can I do when the bike won't start and the security lights are flashing? There is nothing wrong with the key fob.
    Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
    1. Fuel tank empty
    2. Fuel supply valve turned off.
    3. Fouled spark plugs.
    4. Engine flooded with gasoline as a result of over use of enrichner.
    5. Fuel valve or filter clogged.
    6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
    7. Discharged battery, loose or broken battery connections especially the negative cable at "BOTH" ends
    8. Loose wire connection at coil, battery or plug between ignition sensor and module.
    9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
    or cables connected to wrong cylinders.
    10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
    11. Engine lubricant to heavy ( winter operation )
    12. Sticking or damaged valves or push rod wrong length.
    13. Primary cam sproket spline sheared or missing spacer.
    14. Security alarm system not disarming.
    For a primary suspect please visit the website below. Good luck and have nice day.
    Harley Diagnostic Codes 04 to Present
    Apr 09, 2012 | 2009 Harley Davidson FLHRC Road King...
    Why does the red key light stay on while I'm riding?
    Hi Sbgummybear0, take a ride over to your local dealers service department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary and offer professional advice and assistance concerning your issue. Have a nice day.
    Mar 15, 2012 | 2006 Harley Davidson FXDBI Street Bob
    Brake light stay on all the time on a 06 Harley Sporters
    If your brake light is staying on all the time, it's probably a broken front brake light switch. You must disassemble the right side handlebar switch housing to replace the switch.
    Good Luck
    Steve
    May 21, 2011 | Harley Davidson XL 883C Sportster Custom...
    Lands Phones Logo
    113 people viewed this question
    Top Harley Davidson Lands Phones Experts
    David Payne
    David Payne
    WTF Chuck.....
    WTF Chuck.....
    Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
