Question about Canon EOS-5D Digital Camera
What is the best colour setting to have on the 5d?
I recently took some sports day photos in changeable weather (bright sun then cloud) but the greens were far too green and the whole picture looked washed out. I only use L lenses 70-200 F2.8 and the 24-105 F4 the latter lens made everything look like a fisheye effect (another issue!)
On the menu settings which is the best option to have it set up to, to make it look natural?
Also, how do you change the sharpness in camera?
Thanks
MS
    Scholar:
  • 51 Answers
Hi
This all depends on what format you are shooting. For RAW this does not matter as you will be able to change the white balance setting on the computer under your programs white balance settings as the main thing.
For shooting in .jpg probably a good general setting should be cloudy for outdoors. Gives a warmer picture. and for other people the AWB (Auto White Balance) may work fine. Again it depends really on your taste.
If the images are washed out it could be you are shooting in RAW, as this format does not alter any info and is stored on the card as it was taken. .jpg does process the image adding saturation, sharpness etc.
A quick fix for some has been to use the settings under 'Picture Style' and changing thes to suit the subject. Faithful will record things as is and not apply and adjustments and will look a little washed out.
NOTE:
Shooting in RAW gives you complete control over your image but does mean you need to process the shots later on you computer to get them as you saw them.
Note 2:
You are getting the fish Eye effect as on the 24-105 as you are using this on the 24mm end of the Zoom. (Wider end). Try moving it up through to 105.
Hope this helps
Posted on Jul 15, 2008
What does convection in a weather forecast mean?
[img src="http://www.weatherquestions.com/convection.gif" alt="atmospheric convection forming a cloud"> What is convection? "Convection" has several, related meanings in weather....but it always involves rising air. It usually refers to "moist convection", where the excess water vapor in rising air parcels condenses to form a cloud.
The heat released through this condensation can help to sustain the convection by warming the air further and making it rise still higher, which causes more water vapor to condense, so the process feeds on itself.
But convection can also be dry, as occurs on a sunny day over the desert, or in more humid regions early in the day before the convection has become strong enough to form clouds. The sun warms the ground, and convective air currents help to remove the excess heat from the surface. Dry convection also occurs during the day even when clouds are not forming...you just can't see it.
Apr 16, 2014 | Ovens
Panasonic Lumix DMCFX60 Digital Camera - "Sparkling Images become flat in Windows Live Photo"
Try a different photo viewer other than windows photo gallery and see what the results are.
Jan 16, 2013 | Panasonic Lumix DMCFX60 Digital Camera
Why does the grass turn green when spring time comes then?
During the winter and fall months, rain falls less, sun shines less, and the air is much colder. Grass gets its green color from Photosynthetic cells in blades. The more sun and nutrients the grass see the healthier it grows. As the grass sees less sun, water, and is frozen from time to time, its internal processes slow down and many cells die or become dormant. As the rain begins to fall again in the spring and the sun shines longer and stronger it becomes much easier for the blades to transfer nutrients to the entire blade and will become a more full and vibrant green again. you can see this process in action when grass is cut too short in the spring or summer months. The grass will look almost yellow because exposed grass is usually "sun blocked" by the grass just inches higher. Yet in a day or so , you will see the grass turning green again from the botton up but the tips of the grass will remain white and dead until the grass grows and the tips fall off to form the all to familiar grass blade "D
HOPE THIS EXCEEDED YOUR EXPECTATIONS :D
May 09, 2011 | Nintendo Super NES Console
Camera was working just fine, then photos appeared to be distorted with a rose type colour....not sure why this is happening?
Check your settings for "white balance". Unless you know what you're doing, set it to automatic. If you can't find the setting, comment back and I'll find it for you. (On my SD600 it's under Func, and then look for "AWB" instead of a cloud, or a sun or whatever)
Feb 18, 2011 | Canon PowerShot S500 IXUS 500 Digital...
When I take photos with my finepix s1000fd the colours are hardly ever accurate, it will pick out some colours and make them very bright, but the rest of the photo will be a greyish colour. Some photos...
Hello - You will find this happens mostly in Automatic mode which needs a better spread of light.
The grey background is when another color has been highlighted/increased and the background get saturated out (usually the sky goes grey) or the clouds go white.
Try going into Scenic settings ..ie.. vivid , sunset , soft etc and keep that setting open while taking shots.
or -- Use a Neutral density filter where there are bright and dark spots in frame.
or - Use the aep button to increase a stop before taking a picture..
AND -- get into S or A or Manual mode .
I called Fuji Tech support UK and they admitted the S1000 cameras where 1 stop low on light in the fully auto mode, because it was easier to AD light afterwards in software,
Ray
Dec 30, 2010 | Fuji FinePix S1000FD Digital Camera
When taking a photo the picture colour change from a bright sunny day to almost dusk on the screen and on the photo as it is visible when downloaded the photo. This is a new problem I've had the camera for...
Check your EV level settings, possibility is that this could be in minus...
Best way is to Set your camera to factory defaults. If it is due to settings then it will solved your problem.... otherwise get it serviced.
Please rate the answer if you find it useful...
thanks for rating....
Apr 29, 2010 | Canon PowerShot S51S Digital Camera
When i take a picture it looks red , I took in to wal-mart and they told me to send it to you all
thats very helpfull of them??? they dont have a clue do they?
unless your using a red filter to take photos with its this part playing up
all digital cameras and camcorders have whats called a built in
"white balance meter",,,and yours is not working right,,,
the white balence meter is to let the camera see what colour light its seeing in,,,, the colour temperature of sun light on a bright sunny day is 6600 begrees kelvin,,, in an electric light buld is about its about 3500 degrees kelvin or less? if you took a photo in sunlight the camera sees anything white in the photo "as white" and is happy to print it as white,, but in electric light buld it sees "white" as "red" this is due to the drop in colour temperature, your eyes can also see this (but your brain has its own white balance meter built in) what the white balance meter will do is change what it records or see's to take out the red and make it look white insted,,by changing the clolur temprature of the light its taking the photos in try this out,,,
take a white sheet of paper,, go out side on a sunny day and take a photo of it,,, if its not white and it looks a bit red its the white balence meter playing up in the camera,,,
yes i know,,, you hate me now? its as clear as mub "A"
Oct 26, 2009 | Cameras
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
Colours are getting out of sync, picture distortion
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 29, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Canon EOS-5D Digital Camera Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
